Page 107 of 226 FirstFirst ... 75797105106107108109117157207 ... LastLast
Results 1,061 to 1,070 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #1061
    Sep 2012
    NSW
    Quote Originally Posted by Zakarados View Post
    Well after having greater than 1L/1000km oil consumption, my engine decided to give way yesterday displaying EPC and Engine light. NRMA advised it was misfiring.
    I will get it towed to VW tomorrow and see what is going wrong ><! Hopefully this is the cause of the oil consumption.
    This is a repost, but deserves to be in this thread also.
    Just drove me Polo GTi back home. They advised there was oil on the spark plug in cylinder 4. The sparkies were cleaned and a software update applied. I also complained about the oil consumption of 4.5L/4000km. They changed the following "optimised hose for crankcase ventilation" which i assume is the breather pipe people talk about.
    Still getting a lot of soot from the exhaust from the drive home, will have to wait until next month before I can tell how the consumption is going.
    Fingers crossed.
  2. #1062
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by kevinctr View Post
    I never ever go more than 50% throttle or higher revs than 4000rpm before my engine oil reaches 80 degrees celcius.
    Fully agree!
    A friend of mine lead footed a stone cold Ford G6E-T - I told him off!
  3. #1063
    May 2012
    My gti goes in on Monday to have the breather pipe done. He didn't even look at the car. I just told them it had dropped to half way down the dipstick in 5k. He just asked the rego. Funny thing was it hadn't used any for he first 3k then after its first long constant trip it dropped steadily after that.
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
  4. #1064
    Jul 2012
    Camira,Qld
    Took my car to vw yesterday for the oil consumption test and they decided to order in the oil breather pipe. Hopefully this will fix my issue. I have currently used spot on 5ltrs in 10000kms.
    MY 12 Polo Gti - Flash Red - No mods yet
  5. #1065
    Aug 2012
    Brisbane. QLD
    I did the 1000kms just before Xmas, and they told me they topped up 0.5 ltrs of oil which they say is well within VW specifications, but my tailgate is still covered in soot.
    Worst of all the Service manager was contradicting everything the head mechanic told me last time I was in.
    She, the service manager told me that they want to fix the problem, but VW Europe do not believe them. But the head mechanic told me that once I came in after 1000kms, they would write up a report and send it to Europe and wait for a reply.
  6. #1066
    Jan 2013
    Queensland Australia
    Quote Originally Posted by Varnak View Post
    60 per cent of the mechanical losses of internal combustion engines are due to cylinder piston ring contact.
    Was reading through this thread and this comment is very misleading (mechanical losses) is not 60% nor is all that lost through ring contact. The main reason of mechanical losses is the inefficiency of a crank shaft.
  7. #1067
    Mar 2012
    Cronulla, NSW
    I seriously must be one of the lucky ones.
    Only needed to top up 200ml of oil in the 3200km I've had my car.
    Still got a litre in my boot just in case
    Current Ride: Golf GTI Mk7 MY2014|DSG|Carbon Steel
    Previous Ride: Polo GTI MY2012|DSG|RNS510|Shadow Blue|Lenso GF7 18” rims
    Instagram: @lemonskin
  8. #1068
    Sep 2012
    Quote Originally Posted by Lemonskin View Post
    Same here.. haven't used a drop from 3500km to 8000km.
  9. #1069
    Singapore
    Mine too, only moved 1-2mm on the dipstick with 13,000km done but I changed my oil very often. Maybe we could share what we are doing right or its simply pure luck.
  10. #1070
    Singapore
    Quote Originally Posted by Martin View Post
    Fully agree!
    My enthusiast friend used to tell me not to rev the engine hard even when my water temp reach 90 but I do not believe in him as I did not play with oil temp and pressure gauge back then. True enough, after few thousand km my Honda starts to drink oil and 0.7-1L every 7000km to me was a bad sign, furthermore my fuel consumption went up. After I installed oil and water temp/pressure gauges, it was then I realised it really takes sometime for oil temp to reach optimum temp for it to protect the engine well.
