Quote Originally Posted by GTI135 View Post
all good thanks installed 7.5w led h8 globes they work fine and dont give any issues , furthermore they look great too.
Hey dude,
Which brand/seller did you end up using and did they end up matching the DRL's? I have seen 20/30watt globes and I think they are too bright/over power the DRLs a bit. Also without me scavenging through the manual did the turning bulbs use the same 7.5watt LED or something different? Also no error codes or did you disable light check in vcds?
thnx
