Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: DRL's - how to turn them off!
    May 2013
    Melbourne, Victoria
    Quote Originally Posted by AndrewBurns View Post
    I used to not like it but then I stopped caring and now my life is much better
    I have the exact same approach. Once you stop thinking about it, it's really not an issue.
    Still think it would have been nice to have an option to turn them off if wanted.
    Jan 2009
    It's not really the insurance or regulatory aspect that worries me, so much as the inconvenience of being involved in an accident that could have been avoided had the vehicle been less inconspicuous.
    Quote Originally Posted by LukePolo View Post
    I read up on this, according to Australian standard, you are able to use fog lights during the day. As soon as it's dusk, and the weather clear, they have grounds to fine you for incorrect use.
    I don't know if you've ever seen a new VW Passat, during the day, they use the fog lamps as DRL's. The voltage is the same. I find this with the Polo too, people say the Polo's low beams are at a weaker voltage/dimmer state when the headlamp switch is set to 'O', I've hit it with a tester, it's the same.
    If you know of something different then what i've read, please let me know, i don't want to get fined or anything as much as the next person.
    For NSW, rule 218–1 states that:
    The driver of a vehicle must not:
    (a) use any fog light fitted to the vehicle unless the driver is driving in fog, mist or under other atmospheric conditions that restrict visibility...
    Rule 214–1 defines a fog light as:
    a light used to improve the illumination of the road in case of fog, snowfall, heavy rain or a dust storm.
    There is nothing in the regulations which prohibits the use of fog lights during the day. It would pretty silly if there were such a rule, as fog can form at any time during the day (or night), given the right conditions.
    Source: Road Rules 2008 (NSW)
    Okay fair enough.
    I feel as if there are too many contradicting statements in regards to use of vehicle lighting. For example, anytime within 200 metres of another vehicle, it is illegal to use high beams. VW Golf's have high beams as DRL's, at the same voltage and levelling at night when used. A definition of Daytime running lights (DRLs) from NRMA "bright, white, forward-facing lights that improve the forward conspicuousness of vehicles in the daytime, DRLs must be wired so they turn off at night time, as they are so bright they dazzle other drivers at night." tell me how many ways a driver could take that one! Golf's use the high beams, Passat's use the fog lights (although it is a different housing, it is the same globe and portrays the exact same beam as the next cars fog lights), Jetta's use a funny brighter parking light globe. So what is the difference of me turning on my fog lights?
    Just as the housing for the dipped beam, main beam and direction indicator lamp is integrated, so too can the fog and daytime running lamps (if desired by the vehicle manufacturer), but each category of lamp will have their own positioning, geometric visibility and orientation requirements and specifications.
    The bulb type or filament wattage does not necessarily determine the category of lighting.
    The Mk6 & Mk7 Golf uses a H15 halogen bulb which has a dual filament: 15W for the daytime running lamp (full brightness) and parking lamp (reduced brightness) and 55W for the main beam lamp.
    A H7 halogen bulb with a 55W filament is used for the dipped beam.
    Aug 2013
    Quote Originally Posted by Diesel_vert View Post
    Ah! Thank you for that diesel-vert
    I Sell Nissans Skodas.
    IT'S HEREEEEE 18' Skoda Octavia 110tsi Manual Hatch | Race Blue | Tech Pack | Luxury Pack | Panoramic Roof | Turini Alloys | Various VCDS Tweaks | RS Spoiler | Mars Bar Holder
    R.I.P; 13' VW Polo 77tsi Comfortline Manual | Candy White | Sport Pack | Pioneer AVH X3800DAB + Clarion Bass Pack
    Apr 2014
    Melbourne Australia
    Ok ok I'll just leave them on lol. Might get some more 'white' globes - I find the stock ones too yellow that's all. But thanks for the details
    James
    Pacific Paradise QLD
    Okay fair enough.
    The standards have nothing to do with the road rules.
    I don't know where you get the info on the Passat from because the current model Australian Passat has LED DRL in the edge of the headlight housing.
    It has separate cornering lights to the fogs which must be switched on manually.
    The rule for their use is the same in all States and is as written above.
    Most DRL's are not as the NRMA describe and do not dazzle anyone.
    Its the "Wanker " lights that do that, being used illegally.
    Fog lights are not focused as are other lights and that's why they spray light everywhere and blind people.
    Aug 2013
    I am referring to current passats without the xenon kit.
    Some fog lights are focused for example my sideways image (below) of volkswagen fog lights, which are the same as the orbital turning lights in my Polo.
