Results 1 to 2 of 2
Thread: WIP: Polo RATTLE fix list!
    I did a search through the forum to see if there was any similar threads..
    I know there is the Problems and Fixes thread but I think that we all need this specific thread!
    The main purpose is to list the symptoms of your problem and if you've fixed it, list that also.
    For e.g:
    DESCRIPTION:
    Creaking from rear of car.
    SYMPTOMS:
    Consistent creaking from the rear of the car only when driving.
    Also when pushing down on rear end when stationary.
    FIX:
    Replaced rear shock absorber top mounts.
    P/N# 1J0513353D x 2
    DESCRIPTION:
    SYMPTOMS:
    Rear end creaking when going over bumps.
    FIX:
    Re-greased rear sway bar bushes.
    DESCRIPTION:
    Knocking noise in front end.
    SYMPTOMS:
    Knocking noise sounds like it's coming from the lower front right hand wheel well.
    Mainly felt when turning left or right over bumpy roads.
    I can feel it through the pedals and steering wheel.
    TRIED:
    New shorter drop links,
    New strut top mounts and bearings,
    Re-greased brake pad faces,
    Replaced LCA bushes with new SEAT bushes,
    No luck?
    And continue..
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
    Pacific Paradise QLD
    Quote Originally Posted by spraycanmansam View Post
    For e.g:
    DESCRIPTION:
    SYMPTOMS:
    FIX:
    P/N# 1J0513353D x 2
    DESCRIPTION:
    SYMPTOMS:
    FIX:
    DESCRIPTION:
    SYMPTOMS:
    TRIED:
    No luck?
    And continue..
    Add persistent little rattle in rear left quarter
    Sounds like the handle on a zip rattling
    Not shockies as dealer took it out.
    Have bought trim removers so may find it
    Have similar in Passat wagon
    Maybe a VW feature LOL
