Results 1 to 10 of 15
Thread: tyre pressure button
    Mar 2008
    NSW
    can anyone tell me how to use this in the gti?
    ive read the manual and cant figure it out
    thanks!
    Jan 2008
    If you need to reset the pressure that is considered 'normal' then hold it until it beeps.
    Mar 2008
    NSW
    is it meant to warn me if I have a flat tyre?
    Jun 2007
    Sydney, Australia
    Yes, the monitor uses the data feed from your ABS sensors to check the rotation and rolling circumference of each wheel. If the rolling circumference changes then your monitor will display a warning to you. This includes if your tyre pressure increases (in the case of overloading) or decreases (lost of pressure = flat tyre).
    It will not tell you which tyre is a problem you will need to check each tyre yourself.
    Flipper Dog
    Now - T-Roc R, Audi Q5
    Jan 2008
    The light on the dash comes on if you have lost pressure in one, but major blowouts don't seem to show but it has been narrowed down to 'you haven't driven far enough for the system to realise it's blown'.
    Do a search for 'tyre pressure indicator' or similar, there's a long thread about it.
    Mar 2008
    NSW
    ok thanks for the info guys
    just that i had a shredded tyre today and no light came on
    i will search for that thread thanks!
    Sep 2006
    Brisvegas
    search gimmick as i know thts what i put in the title of the thread. and if your cars new maybe it wassnt set in the first place. I thought it was a gimmick but its not as its save my butt a couple of times. The first time my brother hit a rather large rock which punctured it and it didnt set it off. I wonder how many rotations of the wheel it needs for it to react and respond as this is the only reason i can think of it not doing anything as it would have lost air pressure really quick. Not sure if this is the same for you???
    When you go to set it put it in ignition (not actually starting the car) wait for all the beeps and what not and then press and hold the set button in centre consol. You will then hear an auible beep and this means its set. I would check tire presure on all wheels before doing this.
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
    Jun 2008
    so will tyre pressure be set when i get my new car in 2wks time? or i have to preset it?
    Mar 2007
    Quote Originally Posted by leasaunce View Post
    Normally that would be done when the car is prepped ... but if you want to either soften or add pressure to your tires ... it would be best if you reset after you've changed the tire pressures.
    Dave
    Nov 2006
    I think if you need a computer to tell you you have a blow out, you've got more problems then the pressure monitor not working
    aus liebe zum automobil
