Hoyhoy.
Sorry folks for time it has taken, but their here.
Now the main reason I went for this was because there was movement between the subframe & the chassis, now if you don't have movement there it might not make any difference in doing this mod.
I do know it made a lot of difference to my Little Blue Girl.
It can take a bit of fiddleing to fit these, but I made a mark on mine as to where they were & which hole they came from, I can remove the main crossmember out & put it back as it was.
Another problem can be the holes in the subframe, if you have movement, it can damage the 18mm holes like mine did, for this you'll have to burrow a reamer, because you don't want to bash these sleeves in, you must be able to turn them for ajusting.
They have been designed for the Polos, but might fit others.(Sleeves = 18mm dia. with a 12mm hole & the length = 50mm plus the collar.)
This is the kit below that I have available, including a bent spanner to make it easier to ajust.
Have about 20 sets available
Price = $95.00 Plus postage.
I do have PayPal if needed.
http://
Hooroo.
- You may not post replies
- You may not edit your posts
Forum Rules
