Sean, you have a good set up that up that you are happy with. The Bilsteins are top notch and you will not go wrong with the high end KW's if you decide to go that way.
Dependant on how you structure your budget you could revalve the Bilsteins and fit the LSD-(money well spent), then it's lots of seat time. Another additional piece of euipment could be a traqmate, and keeping a record of suspension settings and lap times. IMHO soften the rear sway a bit and see how you go from there.
As you mentioned the high end KW's have adjustable rebound and compression, and you are right about the issue of adjsutability but they are a major factor in chasing lap times, maybe you can consider fitting them sometime down the track (no pun intended) Good luck with the lap times.
