Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Temperature Sensor problem?
  1. #21
    Quote Originally Posted by louis19 View Post
    No, I haven't. Is this something beyond what a VAG scan can detect?
    No, VCDS would trump a generic scanner on VWs
  2. #22
    Feb 2014
    Gold Coast, Queensland
    Ok thanks Gav, hopefully when I catch up with you the scan gives an indication what's happening
    2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
  3. #23
    Feb 2014
    Just wanted to check. Is this the location for the CTS?
    Attached Thumbnails Attached Thumbnails Temperature Sensor problem?-dsc_0074-jpg
  4. #24
    I don't think that's it mate. Is it in a plastic pipe? That looks more like the VVT to me.
  5. #25
    Feb 2014
    Yes, it is in a small plastic pipe. Do you know where I should be looking for the CTS?
    I'm wondering if mine is intermittently not working as today it worked after being warm once turned back on, then at other times again returned to 0..
  6. #26
    Feb 2014
    Update:
    I replaced the coolant temp sensor on the weekend even though when Gav did a full scan on my car and tested the gauges to make sure everything was working correctly it all came back clear. It's really strange, if I turn the car off then back on straight away it will reset to 0 but if I come back after say a half hour or so, it will show the correct temperature. Anyone have any ideas? Starting to think it mist be an electrical problem somewhere along the line?
    Any help appreciated!
  7. #27
    Feb 2014
    Update:
    Anyone have any idea? Guessing it may need to go to an autoelectrition?
  8. #28
    Apr 2014
    Perth
    Don't have any ideas but my car is just started doing this too. What's really puzzling is an obd2 scan says the temp is normal (90 degc) when the gauge is reading zero. Gauge returns to normal after a few mins of driving
  9. #29
    May 2011
    Albury, NSW
    Must be a common Polo GTI thing as mine has just started this a few weeks ago, doesn't sound to be quite as bad as above but it will sit at about 70 degrees permanently, doesn't take long to get there but even after 6 hours of driving it won't spend much time at 90. I was convinced it was the CTS, will see if VCDS picks anything up. It probably should bother me more than it should, but it's been like this for a few weeks now haha.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
