Your level plug is at the front of the trans, 17mm internal hex. The drain is the same plug but underneath. Buy yourself a 17 hex socket. Buy yourself a Tom Thumb pump bottle which hold a litre of fluid, great little filler and no mess whatsoever. You can buy them in any good auto store and last resort you can get it at Autobarn. And make sure the gearbox is level, not the car that some may suggest, when the car is level the box is still a bit canted. The back of the car will be jacked a bit higher to achieve this. Really thats it, good idea is to go for a run and get the oil warm , itll drain quicker that way. Plugs get torqued up to 25NM.
If you are still a bit unsure give me your email address
Jmac
Alba European
