Is it when you first start moving? I think this is an ABS test....
Otherwise, if you car sits for a while, it is the handbrake stuck to the disc... it does it once then goes away...
If you heard a knock when you brake in reverse, its just calipers sliding around and there isn't much you can do about it.
