Er no they're not....
hi guys
I read the manual and it said that the wipers are rain sensing ones
I tried to follow the instructions as per manual but it doesn't really sense anything
do you guys know how to work this feature?
thnx!
yeah i'm pretty sure they are not. there is no sensor on the windscreen anywhere for that function. usually it is on the back of the rear view mirror and on the Polo GTI, there is nothing.
2010 Reflex Silver MK6 Golf GTI
Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
The wipers on the polo GTI's are rain sensing but only when they are left on "intermittent". The wiper/light lever has a switch on top of it that changes the sensitivity of the sensor. I have mine on intermittent all of the time and when it starts raining they come on automatically.
I only noticed this feature when I had accidentally left the wipers on intermittent and a few days later they came on straight away when it rained
If you have the switch set to the far right it will be really sensitive though and may just keep the wipers going if there is a bit of dirt on the windscreen.
The rear one doesn't have a sensor though.
Well he says "I have mine on intermittent all of the time and when it starts raining they come on automatically". I don't believe mine are auto sensing as I have had my windscreen replaced and didn't have to worry bout it (I know MINI windscreens with this feature are diff price to normal). Perhaps it was an upgrade, callen what year build is yours?
aus liebe zum automobil
No, they aren't rain sensing. It also says in the manual in brackets"(If rain sensing wipers are fitted)"
Unless you had it fitted as a factory option, you don't have Rain Sensing Wipers. Also, the 4 position switch on the right hand wiper stalk is only for adjusting intermittent wiper speed, not the sensitivity of the rain sensor. If you also look in the manual, it shows a picture of what the sensor looks like, and where it is located(under the attachment point of the window mounted rear view mirror)...
ohhh...ok
I thought for a few days that I did have rain sensing wipers. I guess I just didn't read it properly.
thanks guy~
yeah the switch on top of the stalk, as dave said, is for the different timing between sweeps on the intermittent wipers.
how long have you had your GTI for bec and callen, this may be a new feature on recent build GTI's...does anyone else have this and what is the build date?
I don't, mine was the last build in 07.
