Accelerometer based tools, such as G-tech, are a bit hit and miss. If this also hooks into GPS, it might be a bit more accurate. As an unapologetic gadget freakI'll probably get this, and report on results
Here's one for any Iphone owners
http://www.autoblog.com/2008/07/29/d...ormance-meter/
okay not so cheap if you don't have an IphoneOne app that has us really psyched is a new automotive performance meter called Dynolicious from BunsenTech. It uses the accelerometer inside the iPhone to let you record 0-10 through 0-100 times, quarter mile and trap speed, Lateral Gs, horsepower and more. Results are also displayed in real-time on the phone itself with graphs and a speedometer
2015 White German SUV
2013 White German hatch
2011 Silver French hot hatch
2008 TR Golf GT TDI DSG
Go for it Timbo
Take it on a real drag strip and post back the different times + speed.
Accurate to 1.5 mph
Even if it's not that accurate it would still be a good way to test out ball park improvements from mods, till you can get some real tests done wouldn't it?
I've seen reports from dragstrip tests against the G-Tech Pro with only thousands of a seconds difference. Its pretty good.
Who cares if it is 0.003s out over 400m
For 15bux it would be worth it for the fun factor, thats about it.
I rekon you could have a comp with your mates to get the biggest G reading around a corner.
2010 Reflex Silver MK6 Golf GTI
Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
For lap timing you can use this for a Nokia S60 phone too:
http://www.racechrono.com/?lang=en
