Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Noisy something on boost
    Jan 2009
    blankedy
    Thanks.
    Anyone using one?
    I need to log, does not sound like a misfire or ping. Not missing any power. I'm running the post-recall coils, not had any issues, but might be something in there. I'll check the spark plugs too.
    Jan 2009
    blankedy
    Found the exhaust manifold bolts, one was mostly out, one is a little out, have not looked for the last one.
    Tightened the 2 I could see, noise was gone.
    Need to get new ones. Thanks for the ideas / advice gents.
    Feb 2013
    Maylands
    Ok I had a drivers side rattle that sounded ad though it was coming through the engine bay. All it was... was a loose headlight torx bolt on the drivers side. Tightened and problem gone. Give this a go. I checked the bolt again the other day and tightened it again. Im looking at experimenting with a rubber washer combined with a locking washer.
    Jan 2009
    blankedy
    Thanks, was loose turbo bolts, as above...
