Page 2 of 2 FirstFirst 12
Results 11 to 20 of 23
Thread: Last days of warranty, what to check for?
    Pacific Paradise QLD
    Hold the button down longer on the remote Should put them up when locking or lower them if you want to on a hot day
    May 2013
    Yeah, does not function on mine
    2008 Polo 9N3 Gti Black Magic + APR Stage 1
    Jan 2009
    Quote Originally Posted by ilz View Post
    Did the APR stage 1 today, The guy's @ Muller & Muller also mentioned the windows should be controllable from the key fob but the issue could be code related, My last Golf had it and I do miss it, can anyone comment on this?
    @noone - did you move or something man, its been months since I've seem you about?
    Recalling a conversation with Jimmy (JMac) going back 4yrs, I don't believe the auto windows is available on the polo's. You can change the door lock sequence, make it beep and what not, but no auto windows. The golf/passat, etc has that feature through VCDS but we lucked out. I haven't researched any further beyond Jimmy's input, but you'd be brave to doubt the man
    Daily: 2010 VW Jetta Highline
    Quote Originally Posted by seangti View Post
    Have just been out and tried our Polo 6R 77Tsi and if I unlock and hold the button down longer the windows ALL go down until I release the button or they get to the bottom. On locking when they are down, holding the button down for several seconds they all go up and car is locked and indicators flash. Was like that from factory May not work on older models though I guess
    Jan 2009
    Hillbilly, i referring to the 9n3 mate, no idea about other 9n's or the 6r.
    Jan 2009
    blankedy
    Yeah, pretty different car in terms of computer controls.
    May 2013
    come to think of it, its possible the headlamp movement came back when all codes were cleared prior to the APR going on..
    That would explain why the following day they worked.
    I did find something on VWVortex regarding the Comfort remote windows thing:
    Polo9n.info
    It states: The function works only with polos from 2001 to 11.2004. It depends on the communication of the control unit. With the older models this works via the CAN-BUS (up to 11.2004 FIN-9N 5-120000 or 9N-5Y120 245) and the newer (11.2004 - 2009) via the LIN BUS!
    have not tested it tho.
    May 2013
    also.. not sure if that contradiction when it states "will only work on 2001 - 11.2004" but then also says "the newer (11.2004 - 2009) via the LIN BUS!" is just something lost in google translate or not..
    someone needs to test, I don't have a rosstech cable personally but I'll take the instructions into my VW guys and see if they can input the codes.
