Hey Spec, if you are going to try to run a pod style filter, you really need to have it shielded from the engine bay heat or you will go backwards. The BMC CDA is carbon so it shields it.
On the polo (and most of the new VW's) you cant run a tube under the battery & headlight down to the lower passengers grill as there is the electric power steer unit located there now!
