Results 1 to 10 of 10
Thread: Chinese made SAI any experience?
    Hi all
    my SAI has the turbo jet noise on cold startup. I know I can ignore it even when the pump finally does fail (been making the noise for over 1 year now still no warning light)
    Anyway I know my options are SAI delete or replace the pump which if I go for genuine makes the SAI delete a cheaper option.
    However I would just replace the pump keep my car stock and found this chinese made aftermarket SAI pumps on amazon for total cost of around $155 delivered which is not too bad.
    Link:
    Amazon.com: Secondary Air Pump 022959253A For VW Eos GOLF V Audi A3 TT 3.2 V6 Polo IV 1.8 GTI: Automotive
    Has anyone had experience with these chinese made pumps? This could be my best option cost wise. Comes with a one year warranty I figure whats to lose?
    My part number is 022959253 but this has an A on the end 022959253 but under OEM it has four part numbers it replaces including 022959253 so it seems to be compatible. Also it seems part number 022959253 got superseded by 022959253A anyway so it definitely should be fine..
    Aug 2007
    They are ok, just remember its the combi valve that has caused it though, ive mentioned this heaps on SAI thread. The combi valve sticks and lets in o2 from the exhaust and corrodes the insides of the pump thus doing its bearing to the point where it will fail. Combi valve, gasket AND the pump as you have mentioned
    Alba European
    Ahh thanks Jimmy.
    So I need combi valve and gasket too.. Does anyone have part numbers for these?
    Ta
    Aug 2013
    Combi valve from a BJX motor:
    http://i34.photobucket.com/albums/d1...psc9c19144.jpg
    Part # 06A 131 085 N
    BJX / 06A 1.8T motor parts (applicable to all 1.8T motors)
    Let me know if you want it (via PM).
    Shipping would be extra (~$20). Based in Melbourne.
    Mike.
    SPA Top Mount | GT3076R | 2200cc | Vi-PEC Standalone | Gizzmo EBC | BUILT Bottom End | BUILT Head | Bosch 040 & BIG Plumbing | Plenty of Bolt-Ons | Plenty of CUSTOM work | Plenty of PAIN
    Cheers so I still need a Gasket??
    That's not a head gasket is it? I thought they were quite expensive
    Aug 2013
    There is a gasket between the cylinder head and combi valve. It's not a hard thing to make out of some diy gasket paper. It's not the head gasket.
    Thanks i think i found one at 403 Forbidden
    Is this what im after it does say its for a 98-2001 passat 1.8 aug engine but i believe thats the same engine in our polp gti?
    Ecs tuning doesnt have an option to select polo as the model. Does it have a different name in the US? TA
    Quote Originally Posted by clone_tk422 View Post
    No Polo's in America officially. That's why there's no selection.
    You shouldn't need that gasket, as there's no need to take the mount off the head. The combi valve is on top of the pillar.
    Ahh ok thx thats confusing then so i just need combi valve and sai. That site said any time you remove the combi valve you need a new gasket
    Jan 2009
    blankedy
    Tuned? GTI?
    Bypass and get CC to kill the code and get more power.
