Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Can a KO4 Polo GTi driver review?
    Nov 2007
    Quote Originally Posted by philthy View Post
    What's that little white car in your sig Johan? How did the Mk1 go getting power down? Did you have an LSD?
    Going off topic here ... again .... but remotely related to power atw ...
    LSD ... yes .... felt like it was on LSD as well ....
    Custom built gearbox with straight cut gears ..... special clutch .... custom built driveshafts (still broke 1) .....
    It had BIG issues getting all the power to the road even with custom built suspension to prevent lift at the front and squatting at the back....
    Getting it off the line was a challenging task requiring restraint and patience. Once rolling its 40-200km/h was absolutely stunning though. With better traction off the line I believe it could have been a 10s car.
    Worst of it all, it wasn't even the fastest Mk1 around .....
    Back to topic .... I believe 200kw atw for a Polo is too much ..... as I said if I want that much power I'd buy a car that would handle it better.
    Mar 2007
    Gold Coast
    Yeah, sorry about the OT.. was just curious about the beast
    As far as I can remember, we have only done 6 K04 Polo's (That we supplied the turbocharger to).
    3 in Brisbane
    1 in Perth
    1 in Sydney
    1 in Melbourne
    That did not include my old K04 off our Polo - That ended up on a MKIV up here!
    You will find K04 owners are very quiet - they like to remain very anonymous - There are at least a couple of owners on this forum who don't post about their K04's
    Dec 2006
    Gold Coast
    If you already have the exhaust, you don't need anything else but the K04 as it simply bolts on and all fittings and feeds work perfectly. So fitting it will only cost you about $2K including 4bar FPR and software.
    If you go anything else there are manifolds, exhaust mods, oil feed mods, software, etc to be done and $5K is probably optimistic.
    Difference is K04 is worth 150+kw atw whereas a bigger yet turbo kit will be 200+kw atw......
    Considering the traction problems of the Polos do you really want 200+kw atw? ...... Realistic answer is no ..... power hungry answer is yes ....
    K04 is as far as my Polo will go. I'll buy a better car if I need more power than that.
    Id love 200+ kw. Id even like 300kw.
    It would be quite nice.
    Dec 2006
    Gold Coast
    What MPH were you running when you ran a 12.3?
    Jan 2008
    Cremorne, Melbourne
    Quote Originally Posted by Kai View Post
    it says in his V-Pic gallery for that car.... 12.3sec @ 198km/h !!!
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
    Jul 2007
    Gold Coast
    agree. 200kw in a pog is too much.
    plus u will need better suspension setup, bigger brake and heart!
    a car should handle well enough first to hav more power imo
    Nov 2007
    Quote Originally Posted by [-Polo GTI-] View Post
    It really picked up speed over the last 300m .... Nissan 1400 utes (rear wheel drives and very light) with Toyota 1600 4AGZE motors with T3/T4 turbos were doing low-mid 10s @ 200-210km/h, so trap speed at 400m was pretty close. In gear rolling runs with those same little utes had nothing in it either way.
    There were a few Mk1's running 20V 1.8T motors (suitably modified) and most power I ever saw from 1 was 347kw atw with liberal doses of nitrous.
    The stage 3 kit from APR (and others) are good for around 260kw atf and is as high as you realistically can take the stock internals. For any more you do need to start doing serious internal upgrades.......
    It becomes a very expensive hobby and the ratio on extra power returns for every $ spent turns nasty.
    Dec 2006
    Gold Coast
    mmmmm 123mph.
    Did you use slicks? With that power to weight your mph should have been 128+. I guess traction was the major issue.
    Dont you miss not having that faster car? I couldnt live without it.
    Nov 2007
    mmmmm 123mph.
    No slicks (Toyo Proxes T1Rs only) so traction was a MAJOR issue .... all the time ..... nothing like wheelspin in 3rd gear at will while moving .....
    Do I miss it .... for sure .... would I do it again .... probably .... much to my wife's dismay.
    Every time I see a nice 2 door Mk1 she has to physically restrain me.
