Page 7 of 40 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 393
Thread: Tips for breaking in a brand new engine?
  1. #61
    Nov 2009
    Quote Originally Posted by Syd118TSI View Post
    The more I read about breaking in, the more confused I get.
    Was planning on ensuring that the speed and revs are not kept constant, which may not be that easy with the DSG.
    What does everyone think about running in in 'S' vs 'D'? Any merit in running in in 'S' mode as it will give more freedom for the engine to rev?
    I'd expect that driving in Sport mode will just annoy you very quickly. In my experience, it'll rev higher than is comfortable for everyday driving. AFAIK, higher engine speeds aren't what you should be aiming for during the early stages of run-in, but rather varying the engine speed regularly, to ensure matching/consistent/smooth surfaces between the various moving parts.
    Push the lever to manual and do the gear shifting yourself from time to time. Drive the car gently but don't baby it completely, and if you're cruising along straight stretches of road without undulations (for variation in engine load), or changes in engine speed, then just shift down a gear or two for a couple of minutes, and then shift back. Rinse. Repeat.
    I'm only going to be doing the above for the first couple of thousand km before I pay less attention to it; by that stage the parts should have machined to each other nicely. Then it'll be time to start increasing the maximum engine speed and throttle load. By 5,000km I'll probably give it the full welly occasionally.
  2. #62
    Nov 2009
    Quote Originally Posted by G-rig View Post
    Just do what it says in the manual.
    Which is, incidentally, take it easy for the first 1,000km or so (from memory). I think they recommend staying below 75% of maximum speed (road speed and possibly engine speed too). 75% is probably a very sane limit for engine speed and load IMO.
  3. #63
    Quote Originally Posted by AdamD View Post
    This sounds good. I'll definitely give the 'manual' shifting a go and will take the car on a nice varied drive for a couple of hundred kilometres on the first weekend, as a lot of the regular driving in this car will be on a long straight flat road at 100/110 km/h and will be the Mrs behind the wheel for those trips.... not too sure she'll be keen to do the shifting herself, so may suggest she take a different route for a couple of weeks.
  4. #64
    Feb 2010
    NSW
    Quote Originally Posted by hooba View Post
    It took me a while however I finally found the article I was looking for on this. From a previous car I know a world renown engine builder to subscribes to the same theory put forward in the article (he does them on a dyno), have a read and look at the pictures of the pistons and make up your own mind.
    Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
    This one is also worth having a read of.
    New Engine Break-in Procedure
    Don't like the first article, the second one is good - its basicaly saying the same as most on here have said - vary the load, but don't flog the piss out of it (ie rev the crap out of it.)
    Its here!
  5. #65
    Nov 2009
    NSW
    Guys my dealer told me the engine was broken in at the factory and that i can go ahead and drive it how i want?..
    2010 5 DR MK6 GTI|DSG|CARBON STEEL|18" DETROIT|ACC|BI-XENON|LEATHER|SUNROOF|DYNAUDIO|SATNAV|MDI|PREMIUM BT|TINTS|EXTENDED WARRANTY| In garage
  6. #66
    Erskineville, NSW
    Quote Originally Posted by Mk6 GTI View Post
    That contradicts what the factory manual says. One is in writing & the other verbal. I doubt the salesman would stand behind his advice if something went wrong.
    I'd have no problems driving my car "normally" straight from the showroom but there are some tosspots out there with little mechanical sympathy that would probably push too hard at the start.
  7. #67
    Nov 2009
    NSW
    Fair enough well i didnt push past 4000 rpm in the first 1000 kms. Maybe accidently a few times! But nothing full on. Im at 1200 now. Ive hit 5000rpm since going over 1000kms.
    Being at 1200kms.. how hard can i push?
  8. #68
    Mar 2010
    Basically what he told me as well, and it wasn't the salesman, it was the service department guy.
    But yeah i have reved my car to like 7000 rpm a few times in sport mode. Time will tell i guess if my car fracks up sooner then all yours.
    MK7.5 R|Lapiz Blue|DAP|Sunroof|Tint
    SOLD MK7 GTI|DSG|Carbon Steel|Leather|Panoramic Sunroof|Bi-Xenon Lights|Driver Assist|Tint|Euro Plates
    SOLD MK6 GTI|5 Door DSG|Carbon Steel|Leather|Sunroof|Electric Driver Seat|MDI|Tint
  9. #69
    Nov 2009
    NSW
    Quote Originally Posted by kennyc View Post
    Well the salesman that told me had just been on GTI training. I havent even used sports mode yet because its going to rev right out. Ill hold back untill 2000kms i think at least just for peace of mind! But i think it is fine either way to be honest..
  10. #70
    Erskineville, NSW
    You should be able to feel the engine going tight - like it doesn't want to rev. I just kept taking mine to that tight point momentarily in 2nd or 3rd, then backing off for a bit & doing it again. It only takes a decent drive of a couple of hundred kms to get to the point where the engine feels reasonably free & responsive.
