Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 82
Thread: Reverse / Reversing light/s
  1. #51
    Jan 2008
    Quote Originally Posted by TeamCrash View Post
    So there is no blub in the LED R tail lights???
    Couldn't you just turn it "on" thru the VCDS
    If there is no bulb there turning it on in VCDS isn't going to achieve a lot!
    (I assume that you mean turning on the other reverse light or fog light via VCDS but they won't work as there is nothing plugged into the controller for that side of the car, VCDS is only required when running another wire from the controller to the rear hatch if you were installing a second reverse light or a second fog light - the easiest way to do this is to modify the harness in the hatch and "jumper" the other light across but it can have drawbacks if too much power is drawn with the controller shutting it down thinking there is a short or other fault)
  2. #52
    Feb 2009
    Sydney, Australia
    As we didn't see any changes to say that the rear fog light would be removed in MY11 or MY11.5 models, I'm sure that the foglight is actually there, and has just been overlooked...
  3. #53
    Jan 2008
    Quote Originally Posted by Corey_R View Post
    The bulb for the fog light will be there as there is no inner light available without either reverse or fog light. It will be a failure to RTFM or look at the light switch! Even the R32 without front fog lights had the rear fog lights and I doubt there is a VW on the market now without a rear fog light.
  4. #54
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by Maverick View Post
    Exactly... and if they did, then it'd also be inexplicable about why they wouldn't have just given us the rear lights with the 2 reverse lights which are already used in other markets where rear fog lights are not provided....
  5. #55
    Im pretty damn certain that i do not have a fog light at the back of my R. Where is the fog light "switch" located to turn them on?? There are the 2x reflectors in the bumper (one on each side of course), and then the tailights. And the taillights only have parker light / brake light section, and then indicators and 1x reverse light.
    Quote Originally Posted by DDTW View Post
    Have you tried pulling the light switch? That activates a bloody bright rear fog light which could be used to illuminate whatever you need to.
  6. #56
    Apr 2010
    Turn the light switch all the way to the right then 'pull' it out towards you.
  7. #57
    Just tried this and......nothing.
    Can someone with a Golf R be kind enough to take a photo of their "rear fog light". Looks like mine doesn't have one (car built Jan 2011)
    Could you take a picture of the fog light for me. Headlight switch on and pulled out.....and nothing.
  8. #58
    Jan 2008
    What will taking a photo of the fog light do? RTFM, turn the switch to the correct position, a light will illuminate in the instrument cluster and a bright red light that is not exactly hard to miss will originate from your behind. The ignition needs to be turned on or the engine running for the light to operate.
  9. #59
    Nov 2010
    Melbourne, VIC
    Then it's time to call your dealer it's a pretty simple task to activate it really...if you've done as we've advised but have no results then something's wrong.
  10. #60
    Didnt have the ignition switched on when i tried it earlier. Funny that the ignition needs to be on to turn the fog light on, but every other light works without it.....bloody Germans.
    So i stand corrected - there is a foglight.....although i doubt ill ever use it.
