Quote:
Technical product information (VW)
Transaction No.: 2035345/1
Transmission: DSG complaints (All vehicles with DQ200)
Release date: 28-Oct-2013
Customer statement / workshop findings
Customer statement:
• Brief rubbing/clattering noise when accelerating from low speed in 2nd gear.
or
• Juddering/clattering when accelerating in 2nd gear for about 1-2 seconds (for example when turning off or reaccelerating between 5 and 10 km/h).
or
• Vibrations, juddering/clattering when changing from 1st to 2nd gear at low speed (no individual jerk).
or
• Juddering/clattering when pulling away.
or
• Uncomfortable gear change (individual jerk).
Workshop findings:
• One or several of the customer statements can be reproduced.
Technical background
Production change
Measure
Try to reproduce the customer complaint so that it can be clearly assigned to this TPI. The following measure must only be carried out, if all the criteria (model/type, chassis number, engine/gearbox code, PR number(s), part number, software version etc.) Otherwise this solution won't work and repeat repairs may be necessary. In such a case, we may reject the warranty claim and redebit the parts.
• Test drive the vehicle.
‒ If the customer complaint cannot be reproduced, no warranty repairs must be carried out.
See attached argumentation. (provided by above links)
If the complaint is confirmed, proceed as follows:
Make sure that the software versions of the control units are up-to-date.
• Perform the guided fault finding
‒ Deal with any entries according to the guided fault finding. Reassess the complaint.
• Check whether a relevant TPI has been published:
‒ If a TPI is available, complete it.
• If the complaint persists, perform a basic settings of the gearbox according to the guided functions.
• Perform an adaptation drive and check whether the complaint persists. A requirement is that the diagnosis protocol confirms the basic settings of the gearbox (in the measured value blocks 180 and 200 of the gearbox control unit the successful adaptation points are counted in the 1st place).
• If the complaint is unchanged, contact the importer.
• For goodwill accounting a record of the complete application of repair instructions (TPI) or the diagnosis (guided fault finding) is necessary. Complete the attached document and include it with the warranty claim.
The "arguments and assessment" from VAG about related issue (shudder and etc.) discover
Quote:
... The electronic control of the couplings in the DSG tried to offer the same comfort as a converter automatic at a high level. In individual situations succeed due to the technical limitations not in its entirety.
... The DSG gearbox takes control of the clutches of a learned characteristic field. It may be possible in some cases that for a certain situation is (still) not optimally engineered in the control unit and the driver experienced this as easy plucking at the start-up."
Also, please take a look at next indicative info
