I've just emailed my service manager to book in a test drive with a mechanic.
Can you please let me know what VW tell you. If they fix it or not.
I'm thinking of taking it back and getting them to check the heat shield isn't loose.
GTI MKVI Candy White | 5 door | DSG | ACC | 18" Detroits | Leather | Electric Seat | Sunroof | RNS510 | Dynaudio | Park Assist | RVC | MDI
Heat shield rattle was something I picked up on a friends vehicle. Dealer diagnosed the actual problem. The fuel clip issue is intermittent and my dealer stated it was a common problem with the MKV GTI. Both a quick fixes. Not sure about the exhaust bedding in; it would be either a loose exhaust clip or some other problem.
Cheers.
WJ
Just got the car back with the diagnosis that it is a rattle of the flap and rods of the wastegate upon start of boost at around 2400 - 3000rpm. This is from an internal bulletin. Bulletin also states NOT to fix and that it is a characteristic of the car.
I also had triple-confirmed that the service centre is aware of the fancy RNS-510 firmware on the my-gti.com website, and that it has not been released in Australia and will void my warranty on the unit if installed.
So my GTI has a rattle that makes it sound like a Datsun with a bung muffler and I'm unable to use SD cards larger than 2GB.
Conclusion: really not happy with my first experience with VW service (though not necessarily the specific dealer).
More about it here:
http://forums.motivemag.com/zerothre...ostid=63483518
and here:
http://forums.vwvortex.com/zerothread?id=4098548&page=1
It seems that it affects many or all 2.0 TSI engines. The first forum lifts the actual VW bulletin from another site:
Judging by the number of pages on the 2nd forum, it's quite widespread and certainly distracting enough for owners to bring it up. Perhaps if enough people complain, VW will be forced to actually address the problem. Those with cars on order, too, should register their concern.Technical product information Transaction No.: 2021062/1
Rattling noises from engine/exhaust system Release date: 10-Jul-2009
Customer statement / workshop findings
Rattling or jarring noise from the engine compartment / exhaust system when accelerating between 2400 and 3000 rpm .
Technical background
Waste gate adjustment rod of the turbo charger rattles when accelerating.
Production change
Measure
Do not repair, the noises are construction-related and normal. There is no parts damage.
Warranty accounting instructions
This is no fault in the sense of warranty.
Mine actually occurs from slightly lower revs - around 2000 - and it's loud enough for passengers to notice if the stereo is off or low, especially with the windows down.
Hi MurphyTheElf,
I have some kind of noise but not sure is it same like on Your GTI.
It is not easy for me to describe it (not sure is it easy to record it as I did it with squealing noise on my 118TSI)
I am having service in 2 weeks ... just wandering is it possible that I meet You somewhere in Perth to compare noises.
Thanks
Mirsad
MY16 GTI 40
I am getting a kind of intermittent rattle but I'm not sure if it is the same as what is described so far...
Mine actually happens when coasting at low revs with NO throttle input - best way to describe the sound is like deep, short burps coming from the engine bay in front of the driver. Not too loud but did have music on when I first noticed it.
Took it to a dealer for a quick check but of course Murphy's law I couldn't replicate the noise for them. They told me it was probably the wastegate operating normally but I would like a definite answer for peace of mind...
Mk6 GTI 5DR - BLACK / DSG / LEATHER / SUNROOF / MDI
2010 5 DR MK6 GTI|DSG|CARBON STEEL|18" DETROIT|ACC|BI-XENON|LEATHER|SUNROOF|DYNAUDIO|SATNAV|MDI|PREMIUM BT|TINTS|EXTENDED WARRANTY| In garage
I had a test drive of my GTI booked in with the service department to investigate the rattle on Wednesday, but was called out of town on business, so I had to reschedule until next Tuesday. From the updates to this thread it sounds like this is a normal sound and something we shouldn't be concerned about, but it just doesn't seem right.
I'll still take mine in and see what VW have to say...
In the garage: Candy White 5Dr GTI VI, DSG, leather, ACC, 18" Detroits, MDI, Bluetooth
Now I know the rev range and the cause, I find it very easy to replicate now. The level of acceleration is as important as the rev range. If you accelerate too hard, none of the boost is "wasted" and therefore all you hear is the glorious turbo whine and exhaust burble. Too soft and the turbo doesn't really kick in at all. You need moderate acceleration between 2000 and 3000 rpm, best off starting from 1st or 2nd gear to minimise engine and road noise. Winding all the windows down and having an otherwise quiet environment helps.
The conditions sound very specific, but it falls in the "normal, sensible driving" category. Perhaps that's why many GTI owners aren't noticing it at all....![]()
