Results 1 to 4 of 4
Thread: Noise when driving over bumps
    QLD Brisbane
    Hi Guys,
    Last night I turn off the radio and drove for good hour and noticed some noise from rear or the passenger side. It sounds like two coins scratching together in high pitch noise when I drove some bumps. It only happens when I drove over the bumps or uneven roads. My friend say he has this problem with MK V and it is the back seats where it is not properly cllick on and he have to put some paper or carboards in the rear seats to stop the noise.
    Just wondering if anyone out there has the same problem??
    Jan 2008
    Quote Originally Posted by EWT View Post
    Hi Guys,
    First of you need to identify where the problem is. Start by folding the back seats down and so on and so froth until you find where the noise is coming from.
    A few common problems and fixes are here - http://www.my-gti.com/category/diy/squeaks-and-rattles
    Apr 2010
    Adelaide, South Australia
    Hi Guys,
    I have noticed similar thing exactly what you described especially when ACC switched on sport mode...I couldn't tell if it is passenger side or back seat....
    GTI carbon steel g, leather, mdi, A.C.C., park parallel assist & RVC, dynaudio, sunroof, R-tails, RNS510, 9WZ, LED reg
    Albion QLD
    Is it definitely coming from the inside of the vehicle? I had the same issue with my front left wheel and it turns out it was the brake bad clicking against the caliper as a clip had broken off.
    2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
