Engine Computer Hackers Show You How To Disable The VW Golf R's Stability Control
Above is a link on how to disable ESP on a Golf R using VCDS.
Remember Caveat Emptor.![]()
R's post June 2011, you can disable it much more easily though cant you ?
Hold the button down until both are off
8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
The console doesn't actually let you totally disable ESP - it just puts it in a milder setting.
Love to hear from someone who tries this mod![]()
Resident grumpy old fart
Link: Golf R ESC DIY
Don't see the point of it in my case since I'll never be on a track and FWD cars will just understeer.
Not quite. The ESP can be put into a suspended state, but if you touch the brake while you're having a moment, the car will automatically re-enable it. This is a safer compromise for road use, but still doesn't make the car 100% track-friendly. In the US, they don't even get that feature - it's ESP-on all the way.
The mod being discussed on VWVortex will disable the ESP completely - it won't be re-enabled by a touch of the brakes. Only by switching ESP back on or restarting the car will it kick in.
That is for the US R though ?
So will this work on a 2011 or is it just post 2012 and us models???
YAY I got my R!!!! White, recaro seats, 19" wheels, bluetooth, reverse camera
Apparently you need this specific ABS Controller hardware, and this (or later) software:
Apparently a part number ending in BG may also work in some cases. However, these parts appear to be specific to late 2011+ build Golf Rs, GTIs, TSIs and TDIs, Skoda Octavia, etc.Originally Posted by VWVortex
Several Golf GTIs with this same ABS Controller have also accepted the coding change and will allow the ESP to be disabled. AFAIK it's just US and Canadian cars that have been coded successfully thus far.
