Results 1 to 3 of 3
Thread: VChecker Pro - does it work with MK6
    Dec 2009
    PERTH, WA
    My Vchecker Professional plugs into my MK6, but when I follow the instructions to read the fault codes as follows:
    Select 1. Control Modules
    Select 01. Engine Electronics
    I get a prompt which is not in the manual.
    Can Bus
    Non-Canbus mode
    I've tried both the above options, but it leads to a comm error message.
    On the back of my VChecker Professional is lists:
    CAN Bus
    KWP2000
    KWP1281
    So my question is, has anyone else go a Vchecker Professional like mine that works with their MK6?
    Zano - PERTH, WA
    MY09 Golf MKVI TDI 2.0, DSG, Sports Pack
    I don't have the actual VChecker device you are talking about - but your MK6 has the CANBUS system so you will want it set to CANBUS mode.
    For what its worth, every device i have plugged into my car has worked (Ross Tech VCDS / ElmScan / DNA Tuning hand controller / Bluefin hand controller).
    Nov 2009
    You're probably better off asking this question in the Electronics or VCDS forums:
    VW Car Audio and Electronics
    VCDS Technical Resources
