Results 11 to 20 of 22
Thread: GTi Question
    Jan 2009
    blankedy
    ESP can not be fully switched off, I don't think VW want you to be able to fully disengage stability programs. On the Polo with ESP switched off, you can happily spin the wheels, ABS and other items stay on.
    You MAY be able to pull a fuse to disengage these systems (but may just cause car to run slower as it detects a fault).
    MPS has rev limiter in 1st and 2nd from memory, so you are likely to have similar issues / limitations with the Mazda's as well.
    APR program is switchable (have a look at GOAPR.com.au). I believe APR (and likely other vendors) will reload software if it happens to be wiped (just ask).
    Personally, for a track car I think the Golf is pretty heavy (1343kgs?) You MAY be interested in the new Polo GTI which will supposedly have the 1.4 TFSI engine, will not be far off a Tone curb weight. No dates on the Polo, GTI may not even be this year...
    Nov 2006
    Canberra, Australia
    First things first ... GTI
    ...not GTi.
    Secondly, I reckon in a skid pan environment you'll still be able to have enough fun with the ESP "off". I don't think it stays on that much so as to thwart super extreme conditions.
    ...MPS has rev limiter in 1st and 2nd from memory, so you are likely to have similar issues / limitations with the Mazda's as well...
    Yeah, the S3 is similar to this, although I haven't found any literature to confirm this. But if you have the car in neutral and put your foot flat on the gas pedal the car won't rev past 4000rpm. While there is a two stage switching process to turn off ASR (traction control), then ESP, when I had the S3 on the skidpan I was unable to properly spin the wheels from a standing start.
    However, power sliding out of corners was still possible (after using handbrake to induce the slide)!
    MY10 S3 3dr
    Feb 2010
    They both will be reflashed anyway. So nobody has heard anything about the ESP being turned off via tuning?
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by Lima View Post
    ...not GTi.
    Thanks for saying that, I was starting to think that GTi3dr thought he looking at a Peugot or Suzuki
    Quote Originally Posted by GTi3dr View Post
    An APR representative has stated somewhere (sorry, I can't find the post right now) that they can completely disable the ESP on a car designated for track use. You may wish to give Guy @ Harding Performance in QLD a call and ask him the question. Please note that I'm not sure on the legal situations around this and whether they're allowed to do it for a car which will also be road registered etc, so please talk to them directly.
    so there are no box's that you can carry with you?
    As niulf said on the previous page, Bluefin have one which is available. A friend of mine has one for his GTI Pirelli. I'm not really sure of the benefit of one, it's rather rare for VW to reflash your ECU....
    Mar 2007
    Gold Coast
    Revo Technick, GIAC and ChippedUK all do hand held boxes as well.
    Who is messing with my profile?
    My Liberty 3.0R-B does this, albeit with a 5000RPM limit in 1st, clutch in. It's drivetrain protection against full bore dumps.
    For a track car maybe one of these is better... pity no new ones still around
    http://www.carsales.com.au/all-cars/...tt=r26&trecs=7
    Nov 2009
    Motor magazine has done a few write-ups on the MkVI GTI, and are pretty critical of the fact the ESP can't be fully disabled. They claim it slows the car substantially in terms of track lap times when in the hands of a pro, and from the way they describe it, I would not automatically conclude that the ESP OFF button raises the ESP threshold much, if at all. I recall reading that all the ESP OFF button does is disable the traction control (happy to be corrected if this isn't the case, but it'd be good to get a definitive answer either way).
    If motorkhana is your thing, and you're not 100% clear on what the available mods can do for you, I'd hold off on a purchase till you can verify the car's behaviour meets your needs (or otherwise).
    Jan 2010
    se queensland
    Quote Originally Posted by dave- View Post
    LOL you're not serious are you? What better way to make good use of the purchase!!
    May as well get a barina with free sunroof and drive from a-b!
    you'd look good in a barina dave
    2012 MY 13 Skoda Octavia VRS TDI liftback Brilliant Silver - Stock
    Jan 2010
    se queensland
    Quote Originally Posted by Rocket36 View Post
    Drive them to the limits. What's the point in owning something and not using it to its full potential? Especially when the full potential of the higher performance models costs a lot more. I'd hardly call driving a car within the limits of its capability "thrashing". I had mine at a track day for its run-in, two days after I bought it!
    Lets get a survey going. Not everyone who buys a "sportscar" is a boyracer!
    I am sure if diehards like yourself were the only purchasers the GTI wouldn't exist ie limited market.
