I completely agree with you! I love the sound of the turbo spool and DSG pop! I'm fitting an APR intake on the weekend, so hopefully it will sound even sweeter!!! :)
Printable View
stain steel pipes would make a difference as well you would expect, but thats going to be more than 300 bucks....
Having finally received my R I wish to replace my rear diffuser. Any ideas on the best way to do this? The replacement diffuser is apparently an exact copy of the OEM diffuser, but by the looks of it, it just clips on with no screws. Is it a simple process of pulling the diffuser off at certain angles etc?
why do you want to swap the diffuser if it is the same
Aah, Carbon Fibre. I was thinking maybe it was for a quad exhaust tip or something ;)
I any case, I'm not sure how it attaches. Sorry!
Haha I was wondering the same until his reply!
I removed those little winglets things on the guards last night that are fitted to cars with 19's. The front ones were a b1tch as they have some serious hold double sided tape which I'll have to cleanup and a single screw (using a security type bit).
Full lock left hander into work with a fair bit of bumps (and ACC in sport) and it rubbed same as before. Guess the wheels are just a bit too big for the car? At least it looks better!
