Had a shakedown run on the dyno this morning to see how the car was running and to iron out some issues with the fuelling. Looks like we'll need a beefier fuel pump controller as the high pressure fuel pump draws too much current for the standard controller - APR are working on the issue and looks like the fix is simply grabbing a controller out of the TTRS to match the TTRS pump.
Despite that, and the dyno operator backing off as the car leaned out a bit too much for his comfort, the R pulled a nice 262.5kW at all 4 wheels.
The dip in the graph is the DSG trying to sort out the additional power as the boost comes on strong - will be interesting to see if that still happens once we upgrade the clutch packs. You do get a brief but noticeable 'pause' in acceleration on the road so it makes sense to see this correlation on the dyno graph.
For comparison on the same dyno we pulled 188.5kW with just the Stage 1 tune, so a net gain of 74kW at the wheels.
