Originally Posted by
AJW
I've also got a similar fault with my car - just under 3 years old - 50K GTI DSG
When it's cold it misses pretty badly, it's especially bad around the 1000-3000rpm range under load.
Off throttle and idling it seems ok , maybe a touch rough on idle.
I can watch the oil and water temp and when they get to running temp, about 6mins, the car is fine.
The car did show some error codes and I've had the N80 valve, Evap can Tube & Evap Canister replaced.
But after this it's still doing it.
As it only does it for about 6min when really cold it's tricky to show.
Has anyone had this issue and had it resolved?
I had a stutter between 2000 & 3000 rpm, only when the car was cold and after about 5 mins it went away.
Problem solved when engine temp. sensor replaced, no codes came up when car was scanned.
mk VI GTI, manual, reflex silver, basic
