Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 62
Thread: 103TDI Range display
  1. #21
    Feb 2009
    Sydney, Australia
    As I said - the main problem is fuel expansion / contraction with hot and cold weather. Petrol companies don't care in Australia because the expansion means THEY come out in front. It's only in countries which are always cold where the contraction would mean the motorist always comes out in front where the petrol companies can be bothered making a browser which takes that into account.
  2. #22
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by coreying View Post
    Yeah - bowsers obviously also change depending on the weather (hot / cold temps cause the fuel to expand and contract)
    Disagree on that one coreying. It depends on how the bowsers actually measure fuel. If they measure volume, which I suspect they do, then the volume of fuel you get (in litres) will not vary with temperature.
    What will vary with temp is the calorific value of the same volume of fuel. So theoretically 50 litres of cold dense fuel will give you more bang for your buck that 50 litres of hot expanded fuel. It both cases you ARE still getting the exact same volume of fuel. You are getting what you paid for.
    A more sophisticated system would sell you fuel by weight which more accurately reflects the amount of energy for a given quantity regardless of temperature. Having said all this if the temp was a signifigant issue on car size tanks of fuel which I doubt, one can imaging the mileage testers putting in super cool fuel to maximise range which I doubt they actually do.
  3. #23
    Jan 2010
    Condell Park, NSW
    Quote Originally Posted by logger View Post
    Which is actually what the fuel quantity indicators on complex aircraft read... The transmitter is a number of capacitance probes in each tank rather than a simple float system.
    Regards,
    - Anthony.
    VW Tiguan 110TSI Life | Tungsten Silver
  4. #24
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by hoi polloi View Post
    Which is actually what the fuel quantity indicators on complex aircraft read... The transmitter is a number of capacitance probes in each tank rather than a simple float system...
    ...and the capacitance probes typically only form part of the aircraft system. You will find there is also a radiation attenuation densitometer which calculates the density of the fuel, applies this to the levels reported by the capacitance system to derive a fuel weight. Ironically, even with aircraft, the fuel company still meter and fill by volume, whilst the pilots use it by w8.
  5. #25
    Feb 2010
    Smile My highest (so far) is 960 km
    Quote Originally Posted by Frankenstrat View Post
    I filled up the fuel tank on Sunday and was pleasantly surprised to see my MFD informing me I have a range of 1030km. Nice!
    I've had my new Golf (103TDI) for a few weeks. The highest I've had so far is 960 km. At first I was wondering why it was different when I filled it up (I've done some long drives since I had it and some city driving) as I assumed it would be the same each time, but then I found out that the current 'range' is calculated based on various factors, such as your past (recent) average consumption rates.
    btw - This is the first car I've owned with a range display and I'm loving it, along with all the other great Golf features.
    VW
  6. #26
    Feb 2009
    Sydney, Australia
    Check out ACA and Today Tonight who both did stories on this in the past. They specifically compared various pumps in Australia, measuring out exactly 5L. Then back in the lab had 'petroleum experts' re-measured the fuel again to show how much the fuel had 'shrunk' by. They then contrasted that to Canada where all the bowsers are fitted differently so that they measure the fuel differently, since the temps are much colder there the customer would always be winning.
    Anyway - I'm not going to get into a big argument over this or anything - because I'm simply relying on the information from petroleum experts and from current affairs programs. I personally have no scientific expertise in the area, nor could I be bothered doing any real life experiments of my own - cause well, it makes no different in the end. We're not going to change the way Petrol companies do business even if the experts and the current affairs programs are correct.
  7. #27
    Jan 2010
    Condell Park, NSW
    Yeah, I deliberately tried to simplify it a bit (being a car forum, not an aircraft one)...
    Radiation desitometers are certainly used in some systems, but by the time I left the industry they'd well and truly moved on and found better methods of calculating density (without the use of radioactivity)... I'd be surprised if there were any newly designed systems using these - plenty of legacy installations out there (Boeing 767 etc. etc.)
    As an aside, XD and XE Falcons use a capacitance type sender...
    Regards,
    - Anthony.
  8. #28
    Feb 2010
    A bit 'off topic'
    Maybe discussions about 'fuel expansion / contraction with hot and cold weather' or 'petroleum experts' etc.. is getting a bit off topic, IMO.
    VW
  9. #29
    Jul 2009
    Highlands NSW
    Temperature and Volume = The Laws of Physics
    We can't deny the laws of physics. ALL liquids expand when heated and contract when cooled.
    For the purpose of fuel measurement there is an Australian standard which is set at 15 degrees celsius. There are regulations and procedures for volume corrections.
    Here is one link for example
    www.ocba.sa.gov.au/assets/files/volume.pdf
    Sorry to spoil a good argument. You even refer to hot expanded fuel and cold dense fuel, in your statement, apparently interchanging volume and mass. Some merit there though as wouldn't hot fuel be less dense as density is defined as mass divided by volume. Mass the same, volume greater at higher temperature resulting in lower density.
    You know you are getting old when you cancel your order for a 3.6 CC and buy an Icelandic Gray TDI CC instead.
  10. #30
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by Mk6 Golf View Post
    Maybe - that's why I said I'm gonna leave the topic, because it's really beyond the scientific knowledge of myself. But in reality - if the experts are correct - it could actually be very ON topic - as it may explain the discrepency between the bowser and the trip metre
