Results 1 to 6 of 6
Thread: How do I post VCDS Output in a Forum Post
    Jan 2016
    Perth, WA
    Hi All,
    I would like to get some advice on fixing a coding error in my Mk6 GTI and think it would be useful to attach VCDS output. I've looked through the FAQs to see how best to do this but can't find the recommended way to do so.
    Advice on how best to do this would be appreciated.
    Cheers.
    Jan 2016
    Perth, WA
    Thanks for the response h100vw. I was wondering if there was a way to get around the post character limits but still be able to post the entire VCDS output.
    Tried the embed as Code and as html but neither of these seemed embed the pasted text in a code box as happens on some other forums. Is there a different technique that you like to use here?
    Just cut the part for the unit with the bad coding.
    What's the problem that you have?
    Dec 2006
    Kilsyth, VIC
    I was going to suggest the code tags, but I haven't tried really long form text in a while....
    From the test below, you do get 10,000 characters, so maybe split it into two if needed? My last log (that I can find) is only 8,697 so would fit, and even something twice as long should be easy to split to two posts.
    Code:
    Monday,29,November,2021,16:15:14:35849
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 21.9.0.2 (x64)
    Data version: 20210903 DS330.0
    www.Ross-Tech.com
    VIN: XXXXXXXXXXXXXXXXX   License Plate: MRSHWK
    Mileage: 225580km-140168mi   Repair Order:
    Chassis Type: 7H-VN75 (6N0)
    Scan: 01 02 03 04 08 09 10 15 17 19 25 69
    VIN: XXXXXXXXXXXXXXXXX   Mileage: 225580km-140168miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    Address 01: Engine (J623-CCHA)       Labels:. 03L-906-022-CAA.clb
       Part No SW: 03L 906 022 GF    HW: 03L 907 309 K
       Component: R4 2,0L EDC   H32 9130
       Revision: 26H32---    Serial number: 00000000000000 CVN: C8DA09CF
       Coding: 01254012232400080000
       Shop #: WSC 23117 959 96126
       ASAM Dataset: EV_ECM20TDI01103L906022GF 002008
       ROD: EV_ECM20TDI01103L906019DG.rod
       VCID: 6FE724D2B61105F1A8-803A
       VINID: 9E60AAAAA1D8A9160210400910788D7F80
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J217)       Labels:. 0BH-927-711.clb
       Part No SW: 0BT 300 045 F    HW: 0BH 927 711 B
       Component: DSG DQ500-7F  H02 0711
       Revision: 00H02V01    CVN: 00CA3CC6
       Coding: 0014
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_TCMDQ500021 001001
       ROD: EV_TCMDQ500021_001_VW37.rod
       VCID: 3875DF8E83DF8249B9-806C
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 E    HW: 7E0 907 379 E
       Component: ESP MK25A XT  H43 0103
       Revision: 00H43001
       Coding: 108724AD09A8089924A2907AAA6216
       Shop #: WSC 02756 790 49152
       VCID: 346DEBBE97B7662995-8060
    Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
       Part No SW: 7E5 907 040 H    HW: 7E5 907 040 H
       Component: ClimatronicT5 H10 0101
       Revision: 00002001
       Coding: 0002001102
       Shop #: WSC 02757 790 50316
       ASAM Dataset: EV_ClimatronicT5 A01002
       ROD: EV_ClimaAutoT5Basis.rod
       VCID: 2D5BFEDA7C9D37E1DA-8078
       Slave 1:
       Subsystem 1 - Part No SW: 7E5 907 049 A    HW: 7E5 907 049 A
       Component: Heckbedienung  H10 0101
       Serial number: BHB-0010302100010141
    1 Fault Found:
    9481200 - Refrigerant Pressure
              B10AB F0 [008] - Too Low
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 231
                        Mileage: 225439 km
                        Date: 2021.11.29
                        Time: 14:51:36
    Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
       Part No SW: 7H0 937 087 B    HW: 7H0 937 087 B
       Component: BCM T5GP H+4  H46 0207
       Revision: BO046001    Serial number: 0156 044100618
       Coding: A0A0293A0E61240393204000242B8FD40080410F60040000300000000000
       Shop #: WSC 02756 790 00000
       VCID: 336FE8A292B961118C-8066
       Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
       Component: RLS 090210 05  54  0403
       Coding: 03302E
       Subsystem 2 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
       Component: J386__TSG_FT  002 3310
       Serial number: --------------------
       Coding: 010000
       Subsystem 3 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
       Component: J387__TSG_BT  002 3310
       Coding: 000000
       Subsystem 4 - Part No: 7E1 951 171
       Component: DWA-Sensor 00  001 0104
       Coding: 000000
       Subsystem 5 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
       Coding: 000000
       Subsystem 6 - Part No: 7E1 951 171
       Coding: 000000
    1 Fault Found:
    03303 - Response Closing Status of Rear Left Door
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 2
                        Fault Frequency: 223
                        Reset counter: 232
                        Mileage: 218891 km
                        Time Indication: 0
                        Date: 2016.03.29
                        Time: 09:10:15
    Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
       Part No SW: 7E0 919 475 A    HW: 7E0 919 475 A
       Component: PARKHILFE 8K  H10 0008
       Revision: --------    Serial number: 32730921101878
       Coding: 010101
       Shop #: WSC 30114 831 1247424
       ASAM Dataset: EV_VW75XParkAssis8K A01003
       ROD: EV_VW75XParkAssis8K_A01.rod
       VCID: 3065E7AE6BAF5A09F1-8064
    Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
       Part No SW: 7E0 959 655     HW: 7E0 959 655
       Component: VW10Airbag02E H05 0011
       Revision: --------    Serial number: 003E4000BAED
       Coding: 000000000000000000000000000000003245
       Shop #: WSC 02754 790 50316
       ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
       ROD: EV_AirbaVW10BPAVN750.rod
       VCID: 73EF28A2DA3921114C-8026
       Crash sensor for side airbag: driver side:
       Serial number: 3495ZRB405B6094IH0NJ
       Front Passenger's Side Airbag Crash Sensor:
       Serial number: 3505ZRB405E70PNC0ORC
       Rear Side Airbag Crash Sensor (on driver's side):
       Serial number: 3515ZRB40556JIHQF9VR
       Passenger side rear thorax airbag crash sensor:
       Serial number: 3525ZRB40576JIHQP8MU
    Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
       Part No SW: 7E0 920 870 A    HW: 7E0 920 870 A
       Component: KOMBI         H16 0111
       Coding: 160F00
       Shop #: WSC 02756 790 50316
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
       VCID: 27570CF25E611DB120-8072
    Address 19: CAN Gateway (J533)       Labels:. 6N0-909-901-6R.clb
       Part No SW: 6N0 909 901     HW: 7H0 937 087 B
       Component: GW-K-CAN TP20 0207
       Coding: 042300
       VCID: 70E527AEA32F1A09B1-8024
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H16 0111
       Serial number:
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
       ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
    Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
       Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
       Component: Anhaenger     H07 0070
       Revision: 3A001001    Serial number: 00000128849235
       Coding: 0300000100000000
       Shop #: WSC 20117 959 97404
       VCID: 3065E7AE63AF5A09F1-8064
    End-------------------------(Elapsed Time: 03:01)--------------------------
    Jan 2016
    Perth, WA
    I'll give the code tags a crack next time. Thanks Hawk.
    Code:
    Like This
