Results 1 to 10 of 10
Thread: R32 Wheels
    R32 Wheels
    hey i found some wheels and just wondering if they will fit on a mkv 5 r32
    lorinser rs6
    Jan 2008
    Newcastle, NSW
    you will want 5x112 (lorinser being a high-end Mercedes tuner, and Merc fitment being 5x112 PCD i cant see there being a problem there).
    then width and ET. I am guessing 8.5 - 9.5 widths, which will goovern your ET.
    Centre bore may or may not be the same also.
    Are you buying these second-hand or new? If new, they may build the rim to your specs. Ie, you provide them with 5x112, MkV centrebore and width and ET's required and they make the rim like that for you?
    Jan 2007
    You are also going to need some hubcentric rings to allow you to run those wheels as the Merc centerbores are 66mm vs. the VW's of 57.1mm. These can be had for a few bucks at any good tire place.
    gpk_gti Guest
    you will defiantely need to organise some adaptors from H&R or another similar manufacturer.
    Jan 2008
    Newcastle, NSW
    Quote Originally Posted by gpk_gti View Post
    you sure? is this as they are a far safer option than running rings?? (with respect to the CB)
    i ask because i thought the PCD was the same...
    um my dad had them on Merc Clk not 2 long a go, the front wheels are same specs as the stock ones on the r32 but the rear tires are a bit wider i dont know exactly wat specs
    Jan 2008
    Newcastle, NSW
    Quote Originally Posted by geralis32 View Post
    i'd imagine 19" diameter
    look on the underside of the rim and it should say 8.5J or something. thats your width
    then ET XX (XX is a number)
    that will sort fitting, then the centrebore problem. Which as george said, may need adapters for, or hubcentric rings.
    What are you going to do with your R32 Rims?
    MY08 Jetta 2.0 Turbo FSI - OJE774
    Graphite Blue / Beige Leather / Sunroof / 18' Fox Rims / Tint / iPod Adapter / Bluetooth /
    Apr 2008
    If he's selling and you're buying.....what are you going to do with your Classix?
    Graphite Blue TDI| DSG | Leather | Bi-Xenons | Custom LED inner tails | Black Forest TAI | OSIR Pod & New South Boost Gauge | Bluefin | Projector Fogs | RNS510 | Skoda Bluetooth | Eibach Pro kit Springs| Full LED interior|US GLI paddle shift MFSW|Carbon Vinyl wrapped trims|Colour Coded Votex Body Kit|
    Buckets this could work out well for all
    *Geralis which wheels do you have on your R32?
