Originally Posted by
Celestine
Firstly, have you got the 'keys' which unlock the RCD200 from the centre dash in your possession yet? If not, you can simply use 4 Kenwood headunit removal clips to do the job (saves you some money).
There is a support for the headunit which I strongly recommend you purchase as the weight of the headunit may not be sufficiently held in by the cage. The headunit support can be sourced from the previous two 9N series models. To make your life easier as you have decided to put gauges in, you can also purchase a din blank (once again a geniune factory part). You can drill your 52mm hole's into them at where you find appropriate, and at least you wont have fitting issues with the Japanese din being smaller than the Euro din (Japanese din is about 2~3mm's smaller each side); not to mention you'll also have to custom retrofit a mount.
I havent got a scanner but the two parts I mentioned are from VW's 'ETKA', Illustration '857-10'. The headunit support is part '11' and the din blank is '10' on the diagram.
