Results 1 to 10 of 14
Thread: Key not found after starting car
    Jun 2019
    I recently had an additional key coded for my 2012 VW cc (aftermarket) as one of the original keys has been lost.
    Perhaps it is by coincidence, I have been having issues with my original key, where I get the "key not found" error message after starting the car and usually briefly after starting to drive. The centre console (seems like passenger side) also makes a short and rapid clicking sound (like a relay).
    At first I thought it might be the battery in my key fob, which I replaced with a new and reputable branded battery. I have also voltage tested the key fob battery and it's ok,so not a dud.
    Can anyone suggest what might be causing this? And how can I fix this issue? Or troubleshoot it further?
    See below a recording of the issue with the clicking sound and error message display.
    Key issue - Album on Imgur
    Sent from my Pixel 2 XL using Tapatalk
    Is your car KESSY? (keyless with the push button start)
    Your IMGR link doesn't have anything in it.
    Also there is no such thing as a coincidence
    Jun 2019
    Hi there.
    Yes it is kessy.
    Imgur link fixed (I hope!).
    Video is of a couple of occurrences with the rapid clicking sound then the dash "bell" and error display.
    What's your battery like?
    Car battery not key.
    Jun 2019
    Both car battery and key fob battery all ok
    Jun 2019
    Ok, so, I found a guide online to "re-pair" a previously paired key, involving the emergency key lock, inserting fob into dash etc.
    I have made a few trips without receiving the key not found error, but I am still getting that rapid clicking sound every time the central locking is locked. any idea what that might be?
    The location you say the sound is coming from doesn't match the location of the elv, kessy module or BCM.
    Only thing I can think of is the epb which is under the centre console.
    It makes clicks when starting.
    Jun 2019
    Thanks. I just tried to listen around whilst reproducing the sound (locking the doors) and it definitely sounds to be coming from the passenger footwell area/centre console. Back to the drawing board.
    Ah if it's passenger footwell that's where the CCM is - behind the glovebox.
    That's the module that contains the KESSY receiver/authorization.
    Sounds like it may be failing.
    Jun 2019
    Uh oh. Are they expensive and/or difficult to replace?
