Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: in need of advice!! new to diesel engines
    Jul 2012
    victoria
    hi guys, just recently bought a golf tdi mk5!!! #happyboy
    anyway straight to the problem, ive looked around and know that diesels smells... but should it be a really strong smell?
    cos my missus complain that it smells really bad.. and i believe that thats a normal diesel smell...
    also ive noticed that the car smokes when i accelerate, i thought that it was just the unburnt fuel.. but other saying it could be the turbo (also new to turbo cars as well). the funny thing is was that when i put it in park, and go behind the car to have a proper examination while the missus steps on the pedal, there seems to be only smoke coming out when shes flooring it.. so the problem occurs while im driving not when parked.. #strange
    i am going to have it checked out later today by my mechanic.
    just wondering if this is a common issue with other golf tdi's or any turbo diesel cars.
    i also come to term that, i MIGHT need to change the EGR or DPF.. and how would that usually cost? to fix.
    just some details about the car...
    2008 golf TDi mk5
    120,000km on the clock
    just serviced (oil + oil filter)
    replacing timing belt this week.
    was damaged from the back.
    massive thanks in advance!
    Jan 2008
    Sunshine Coast
    Welcome to the learning curve.
    You car does not have a DPF, hence the soot when you floor it. All diesels do that, just the later ones with a particle filter trap that obvious soot. Yep diesels smell different, best not to go out of your way to do so.
    Yep the soot is unburnt fuel .At idle there is no load on the car, so it has no need to inject much fuel, this no soot. On the road, with load, it has to inject more fuel, so when you step on it, the more soot produced.
    Very normal diesel behaviour.
    2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
    Gosford Central Coast NSW
    all sounds perfectly normal!
    enjoy it!
    (PS - when you own diesels for a while, you may come to like the smell.)
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jul 2012
    victoria
    (PS - when you own diesels for a while, you may come to like the smell.)[/QUOTE]
    haha i actually do not mind it.. its just the missus..
    anyway i just to audvolks, in melbourne and he ran diagnostic checks on the car apparently it is not the EGR but
    hes booked me in to remove the EGR and see if there is a mechanical fault.
    btw i dont think a cloud of smoke when i drive off is normal lol, the poor cars behind me all i can see if smoke all over their windscreen :\
    argh! maybe i shouldve picked a japanese car as my first
    Jul 2012
    victoria
    also!!
    forgot to update, there IS smoke coming out when idle, not a lot though.
    Adelaide hills, SA
    Try injector cleaner/fuel additive first. Maybe the previous owner never used additive in the tank. I use Moreys Diesel SMoke Killer at every fill up, that helps a lot. For initial clean up I recommend BG 244K (it may be hard to get-not in retail stores) or Liqui Moly - this brand you can get from Supercheap and Autobarn.
    Dec 2009
    Melb. (SE), VIC
    Get a new girlfriend. Cheaper then replacing the car
    On a more serious note, I doubt a faulty egr valve would cause the smoke.
    What color is the smoke at idle?
    Jul 2012
    victoria
    thanks transporter, will try that tomorrow. and will get back asap!!
    getjet, LOL!! i wish... yeah the guy at audvolks says the same, and its white smoke at idle??
    and my mate a mechanic says that... white smoke = cars ****ed (blown head gasket or turbo whatever)
    but then reassured me that it could also be the diesel filter? water mixing with the diesel causing the smokes?
    anyway its going to come down to a RIDICULOUS amount of cash to fix FML
    Adelaide hills, SA
    Maybe there is nothing to fix.
    The white smoke from the exhaust could be just normal condensation (moisture from air) on cold winter day. The PD diesel engines can be a bit smoky.
    Post some youtube video, if you can.
    Perth, WA
    A bit of black smoke when you floor it is normal... You should see the state of tuned gtis. Mine is worse than an old Massey ferguson under WOT!
    White smoke is a worry though.. Might be worth checking....
    Smell? What smell? We have 2 tdi's in the family and neither have any smell whatsoever? Must be a non dpf thing?
    Love your diesel and it will love you in return!
