Results 1 to 9 of 9
Thread: Engine code...where?
    Apr 2006
    Carlton, VIC (HK now)
    Today I went to Autobart, and I asked for NGK spark plugs, however they said they will need my engine code coz theres quite a few types on da cataloge, however I can only find VIN n chassis No., the plate is stickin on the suspension mount or wadever u call... does anyone know where it's placed?? i know i m an idiot...LOL
    PS: any recommened plugs which are good n last long on Mk3 2lts??
    Carlson
    Jul 2005
    Melbourne, Williamstown
    Correct me if I'm wrong but a mk3 2L I think is a 2E motor code.
    mk2 GTi 16v
    Corrado G60
    syncro Guest
    Quote Originally Posted by ausgolfer
    Isn't there two different 2L engines in the Golf 3?
    A crossflow and a normal?
    Jul 2005
    Not in Australia my friend, unless you look in the first of the new Beetles.
    mk2 GTi 16v
    Corrado G60
    Apr 2006
    Mine should be a normal. I better ask the dealership or look deeper haha
    syncro Guest
    I thought there may have been some Mexican engines here in some Golfs.
    Jul 2005
    Nope. And the engine code will be on the front of the engine block at the top right near where it meets the cylinder head close to the distributor.
    mk2 GTi 16v
    Corrado G60
    Apr 2006
    VW Race HQ - Sydney
    Gold gold gold , you guys are funny .
    All mk3 2l Golfs had the same cylinder head . It was made in Mexico .
    The early mk3 golfs had digifant injection which had hall sender in dizzy . This engine code is 2E , they also used the flapper air flow meter thats also used on t3's and early bmw's , porsche's mercs etc
    The later Mk3's had simos injection which had a crank angle sender in the side of the block , it picked up signals from the flywheel ( 60-2 teeth for those who want to put on aftermarket ecus) The later air flow meter is a hot wire element .
    Power is the same 85kw . The Seat Ibiza gti used only the 2E engine
    The spark plugs I use are : NGK BUR5ET or if you plan on any mods run a slightly colder plug BUR6ET
    Apr 2006
    oh okey, ya mine's ADY i found out, and i got the BUR6ET
Similar Threads
  1. VW Engine Number Chart
    By Golf Loon in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 14-09-2009, 03:20 AM
  2. 2.0 Tdi Oil
    By TDI DSG in forum Fuels and Lubricants
    Last Post: 02-01-2008, 08:37 AM
  3. Replies: 16
    Last Post: 03-07-2007, 10:31 AM
  4. Gen 3 TDI engine conversion
    By dieseldude in forum Diesels
    Last Post: 13-04-2007, 04:17 PM
