Page 1 of 7 123 ... LastLast
Results 1 to 10 of 67
Thread: T5 with DSG and multi function steering wheel question
    IN2VWS Guest
    Hi Guys,
    Does anyone here have a T5 DSG with a multi function steering wheel?
    If yes, does yours have the gear shift buttons on it?
    Nov 2007
    No VW MF Steering wheel has gearshift buttons .... the few models that allow gearshift changes from the wheel all have paddles behind the wheel spokes.
    T5 DSGs with MF steering wheel do not have the paddles. It is not even an option. It may be possible to retrofit though as somebody in a Tiguan (and the same DSG as the T5) has done exactly that. Required recoding using VCDS (Vagcom), but worked fine. MF Steering wheels with paddles can be found on eBay internationally for about $600.
    I have looked at it and it is something I'd like to do in the future as I find the manual mode on the gear lever to be stupid and clumsy. Have to use manual mode often as the stupid attempted engine braking of the DSG on a downhill always results in a shift to 3rd jumping the revs to well over 3500rmin when staying in 5th would have been fine, thus requiring a flick into manual mode to force it to stay in 5th.
    And here is the link to the Tiguan paddle retrofit: http://www.vwwatercooled.org.au/foru...uan-56968.html
    IN2VWS Guest
    Thanks for the info.
    I am going to take the gamble and get a wheel with the paddles, and see if it works.
    I'll let you know how it goes.
    Nov 2007
    Quote Originally Posted by IN2VWS View Post
    Cool I'll be keen to know .... btw here is 1 for sale ....
    VW Golf 5 6 Scirocco Multi-Function Steering Wheel DSG | eBay
    IN2VWS Guest
    Thanks.......I just bought one of these ones. He had one DSG wheel left.
    EOM VW STEERING WHEEL GOLF EOS SCIROCCO PASSAT rns 510 | eBay
    Sydney Australia
    Hi Guys,
    in2,
    Does your Transporter have a Multifunction steering wheel already ?
    if not what other mods will have to be done to make the steering wheel work ?
    the bug
    The VW Bug
    2010 Golf 2.0 103kW TDI Manual White
    2011 Multivan 2.0 132kW TDI Sliver
    2018 Multivan 2.0 TDI White
    IN2VWS Guest
    Yes, I already have the multi function steering wheel.
    I stumbled across the one with paddles because I liked the leather pattern better than the one in my van. So if I can't get the paddles to work, it's not a big deal for me, but it would be cool if it does work. The seller did say that because I have a DSG and a MF wheel already, it should be plug'n'play. I might have to activate the paddles via vagcom.
    I am not sure what has to be done if you were to retro-fit a MF wheel. Not sure if the wiring is there for it or not. Pretty sure the MF wheel is fitted in conjunction with the MF display.
    Mar 2011
    Sidknee
    wanna sell your old leather wheel? I'd be keen
    132kw LWB Van. Not a tradie..
    IN2VWS Guest
    If I like the new wheel when it arrives, and it all works ok, then yes. Your name is on the top of the list.
    Do you have the MFD in your van? otherwise all the buttons on the wheel are pretty useless.......except for the radio controls maybe?????
    Mar 2011
    Sidknee
    no don't have the MFD. just fancy a leather one. was looking at the gti ones with the square bottom.
