Page 146 of 198 FirstFirst ... 4696136144145146147148156196 ... LastLast
Results 1,451 to 1,460 of 1974
  1. #1451
    Quote Originally Posted by ThatsMe View Post
    Hi,
    Is anyone able to give full OBDEleven instructions for the below on a 7.5 Golf R -
    Enable Traffic Sign Recognition
    Remove the drive safely nag screen on head unit at startup
    That'sMe: Sure, but you have to promise not to tell Adam (the SuperModerator) that I've posted OBD11 tweak instructions in a VCDS thread -it's got to be our secret
    TMC is done like this:
    But you need to make sure that the RDS (Radio Data Service) is enabled on the car. I'm not sure if this is factory set by VW on a mk7.5 - some new model Tiggys don't have this enabled as default. So you have select coding in the second screen above and check this:
    You need to check that the entry byte_14_RDS-deactivation is set to No and also (not highlighted in the picture above), make sure that byte13_Radio_Text_Plus is set to Activated
    After you make these changes, I've sometimes found that a reset of the MIB unit is necessary (press and hold down the ON/OFF button until the MIB turns-off, then turns-on again)
    For the nag screen delete, do this:
  2. #1452
    May 2011
    Thanks Don, your a legend!!!
    I disabled the nag screen which works fine, i already had the TMC enabled, but i was after the Traffic Sign Recognition, do you know how to enable this?
    Rik
    P.S. Apologies for having this in the wrong thread.
  3. #1453
    Rik
    Rik: I've not personally implemented the Traffic Sign Recognition tweak, but here's my understanding of the process (in OBD11 speak):
    Note: multi-function camera must be installed.
    Select module called Dashboard @ address hex17
    Select coding
    Navigate to Byte 5, enter tick in Bit 2
    Select module called Information Control Unit 1 @ address hex5F
    Select adaptation
    Search for Car_Function_List_BAP_Gen2
    Select traffic_sign_recognition_0x21 and change setting to enabled
    Search for Car_Function_Adaptations_Gen2
    Select menu_display_road_sign_identification and change setting to enabled
    Select menu_display_road_sign_identification_over_thresho ld_high and change setting to enabled
    Select module called Front Sensors Driver Assistance System (@ address hexA5)
    Select coding
    Navigate to Byte 1, enter tick in Bit 0
    Select Adaptation
    Search and select Display end of speed limit symbol and change to activated
    Search and select Display valid additional signs and set value to 00100111
    Note: if OBD11 asks for a security code for A5, or 5F modules - enter 20103
  4. #1454
    Jun 2017
    I've tried (unsuccessfully) to get rid of the nag screen using VCDS (Ross-Tech V 18.1) but the info provided on this website about doing this process seems to be a bit old or maybe I'm just a bit dim? I am a newbie to this stuff but I have tried to follow the instructions and I don't see exactly the screens as provided. I don't have OBD2. I know it's boring but I have tried to find a clear explanation but have come up short. Is there anyone who could provide some screen shots of the process using the latest version. I have a 7.5R.
    Wolfsburg 7.5R. Lapiz Blue hatch DSG with sunroof.
  5. #1455
    Dec 2017
    QLD Australia
    Quote Originally Posted by iant333 View Post
    You cant rid of the screen as it is not fusion mode which is impossible to do with our maps for TSR
    Sent from my SM-G935F using Tapatalk
  6. #1456
    Apr 2014
    Albany Creek, Qld
    It can be done on a 7.5 R (I've done it). Will get you some screen shots for the current VCDS software when I get a chance (probably tomorrow).
  7. #1457
    Dec 2017
    QLD Australia
    Quote Originally Posted by TJG View Post
    I'll be uber interested as well.
  8. #1458
    Sep 2012
    So I tried to code the 4 brake light mode on my 7.5 R and it accepts the adaptation changes but doesn't work. Doesn't break anything either.
    I'd also like to find the adaptation for lowering the speed at which the high beam automatically comes on. 60km is too fast for dark residential streets.
    Sent from my SM-G950F using Tapatalk
    MY13 Golf GTI DSG (SOLD)| Candy White | 18" Detroits | Bi-Xenon Headlights | Street Guardian SG9665C
    MY18 Golf R DSG | Indium Grey | 19" Spielbergs | DAP | Sunroof | Viofo A119v2 (front) | BlueSkySea B1W (rear)
    Micro-CAN VCDS
  9. #1459
    Aug 2017
    Uk
    Quote Originally Posted by Kevlarman View Post
    the standard (not dynamic)7.5 rear LED lights do not have any lights on the boot clusters for the brake lights (the near side does have a partial one but that’s a fog light)
  10. #1460
    Sep 2012
    Quote Originally Posted by Jap View Post
    Aren't the R tails dynamic? I have that cool "sweeping" turn signal.
    Micro-CAN VCDS
