Page 20 of 31 FirstFirst ... 10181920212230 ... LastLast
Results 191 to 200 of 310
Thread: Kamold's R36
  1. #191
    Yes the issue will recur (I presume)
    It's a flawed (yet still awesome) design.
    You could always put some less sporty seats in. (?)
    I have figured out a 'manouvre' to get in which I am hoping will prolong the new seat base's life.
    I enter rearward first and then put my outside hand onto the door sill to allow me to 'vault' over the bolster.
  2. #192
    Nov 2014
    New Zealand
    yes I've been doing exactly that since I got the car 2 years ago after seeing damaged ones while I was looking for the right car. My drivers bolster still looks mint. Passenger side has a few minor creases in it as wifey hasn't yet mastered the manoeuvre!
    2010 Passat R36 - Icelandic Grey / BT / MDI / Power Tailgate / RVC / Cargo Management System / 19" Lugano Wheels
    2005 35th Anniversary 350Z - Ultra Yellow / Stillen True Dual Exhaust / Motordyne MREV 2 and Plenum Spacer
  3. #193
    Apr 2013
    Sydney NSW
    Quote Originally Posted by Netrover View Post
    Bolster stood no chance while wife was preggies lol, but yes I know the manoeuvre very well myself. Its like launch control.
    I was this close on buying the replacement foam, up until I opened my mailbox after being occupied by our newborn for the last 2 weeks...
  4. #194
    Jul 2014
    I use the steering wheel, I grab it and use it to lever myself in then drop onto the seat. Same to get out. So if the car isn't off and the wheel is free to move it ****s my system up and I struggle to get in and out like some sort of obese person haha.
  5. #195
    Tpms installed
    Was a bit involved in terms of having to remove the rear bumper and run the cables up the front to the canbus gateway but worthwhile I think.
    Can switch between PSI, Bar and kPa.
    Has a table of different tyre/wheel sizes to select from.
    Mine aren't in there but there is a utility available from a developer in Germany (dunt.at) to create a custom table and apply it to the TPMS control module using ODIS.
  6. #196
    Jul 2013
    Hills District
    Top work! Way better than the stock one!
    2018 BMW 125i M Sport |AlpineWhite|719M JetBlack|BlackLeather |ComfortPackage|Sunroof|WirelessCharging
    2010 MY10 R36 Wagon | Biscay Blue | Power Tailgate | RNS510 | MDI | RVC | 51,000 km |Garage Open Button | Dead Pedal Mod | OE Fit DRL | VCDS | Sprint Booster | H&R Rear Sway Bar | Alcantara Steering Wheel | Dual Reverse Light | 19" Bentley Wheels (BBS Forged Split) | Michelin PS 4S
    2005 MY05 AH Astra HatchBlack | Facelifted SRi Looking | OpeliZed | Whiteline RSB | Eibach ProKit
  7. #197
    May 2015
    What does the stock TPMS do - besides telling you that you have low tyre pressures?
    Kamold, what VW model does this TPMS come from?
    Biscay Blue MY10.5 Passat R36 Wagon
    Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC, RVC, BT 9w7, Tint and Factory Towbar.
    Atlantic Blue MY19.5 Golf GTI
    Options: Luxury Package and Sound & Style Package.
  8. #198
    Quote Originally Posted by prn31 View Post
    Stock TPMS in our R36s has sensors in all four wheels. However these are not individually identified should one of them fall below the pressure threshold after you have set it by holding down the TPMS button after you fill your tyres.
    It will ding and show the tyre pressure warning in the dash, then you need to go and check all your tyres.
    The TPMS receiver is embedded in the Central Convenience Module (CCM) located behind the glovebox.
    This TPMS high is from the B7 Passat. However the mounting point for the 3aa907538 bracket which holds the 3AA 907 273H receiver is already available on our cars (behind the rear bumper, just up above the right exhaust), so I assume this was available in other markets as far back as the 2006 introduction of the B6.
  9. #199
    Custom data set applied to the TPMS module
  10. #200
    This is what a warning looks like with tpms direct.
