Originally Posted by
jisses
Don do you have any ide about what the sideblinkers i the mirrors has for Leuchte number
jisses: Hej och välkommen till forumet
Some VW models do have a Leuchte-set for the two blinker repeater LEDs on the side mirrors ( i.e. the new Polo 6C). However, the mk7 does not - alas.
If you look at the wiring diagram for the mk7, you will find that the repeater LEDs are connected directly to the door control modules - there is no physical connection from the LEDs back to the BCM.
Since Leuchte channels ALWAYS reference a pin number on the BCM, it's not possible to have such channels for the repeater LEDs (because they are not connected to the BCM). What I think happens is that the turn signal information (which originates in the steering column control module) is sent to the door control modules and therefore to the repeater LEDs via the convenience CAN bus.
