Results 1 to 10 of 11
Thread: Adding reverse parking sensors: rear grommet? how to remove boot interior?
    Nov 2014
    Aberfoyle Park, SA
    Hi all. I have bought some after-market reversing sensors to add to my Polo and need to get some wires through from inside the rear bumper into the boot. Is there a grommet somewhere back there?
    Also, does anyone know how to remove the plastic panels inside the back of the boot? If I could get those off I may well find a grommet, but I couldn't work out how to remove them.
    Once I can get the wires in I'll tap into the reversing wire for power, but is there an easier way to access that than via the tiny access cut-out in the side carpet?
    Thanks!
    Pepper Grey MY13 Volkswagen Polo 6R 77TSI DSG Comfortline with Comfort pack
    Mar 2011
    Wollongong
    careful. If you cut into the wiring you may void the warranty on the entire electrical system. Thats the speil they threw at me when I choked on the cost of a golf tow bar wiring harness. You'd possibly get bulb warnings too.
    Nov 2014
    Aberfoyle Park, SA
    Thanks amazeer. I was planning to use one of those clamp-on joiners to tap into the reverse light power wire. Hadn't thought about bulb warnings. I'm going to risk it, but I'll sure kick myself if I end up having any warranty issues down the track!
    Pacific Paradise QLD
    Those clamp ons, called scotchlocks are absolutely the worst way to join wires together, bar none.
    If you are going to do it do it right.
    You could buy some time on ERWIN and get the interior diagrams for the Polo May cost as little as $5 for an hour.
    Mamba Ebike to replace Tiguan
    Nov 2014
    Aberfoyle Park, SA
    Thanks HillBilly.
    From googling various related details I think I have worked out that there is a grommet under the back plastic trim near the boot latch. I just need to work out how to remove that piece of trim without breaking anything. Does anyone know if it just lifts off with some reasonable pressure?
    Quote Originally Posted by MickybD View Post
    Thanks HillBilly.
    It pulls straight up but start at one end with a stiff wide thin blade and twist it to lift it I have a set of trim tools which work well.
    A 25mm wide chisel applied carefully may work. All advice no responsibility if you stuff it up.
    Nov 2014
    Aberfoyle Park, SA
    Thanks. I have a set of trim removal tools which I will use.
    No sweat.
    Mar 2011
    Wollongong
    I think the towbar harness plugs into the main harness at the front of the car somewhere. Maybe the factory reverse sensor harness plug is up there too and you could use that as the power source and not have any warranty issues. I have no idea how you would find that harness or whether it would need turned on with VCDS
    Nov 2014
    Aberfoyle Park, SA
    Thanks amazeer. I'll take a look and see what I can find.
    Quote Originally Posted by amazeer View Post
    They would need to be enabled in VCDS Very little is plug and expect it to work in a VW
