Someone posted here pics of a driving light bar they made that fitted behind the grill but I can't find it. Does anyone recall the post, it may have been in a thread started by someone else.
Why would you need it my LED's light up the next postcode almost (Unless you live outback maybe)
Thanks for the reply, not the one I was thinking of but it gives me some idea of how I can make one. I am sure the one I remember seeing was made by the owner of the car and it showed a front shot with the grill removed. I have made a previous version but it is a bit clunky and I don't like it at all.
They also have this but I can’t tell by the pics how it mounts or how solid it would be
VW TIGUAN (2016+) BUMPER BEAM MOUNTING KIT – Forge Motorsport Overland
There was a post with pics like that for a polo install.
led light bar 6c polo gti
G'day I have done it on my 2015 Tiguan.
I have a 2015 Tiguan and I fitted a 32 inch Stedi curved light bar behind the bottom part of the lower grill.
It was "Professionally Fitted" using a Stedi number plate mount first up when I was working in Melbourne in early 2020.
When I moved back to Townville I refitted it to its current position.
The Front bar reinforcement is hardened steel which I could not drill thru with cobalt drills.
I got the four bolt holes water jet cut by a local sheet metal shop ( Cost $50 )
I am a Aircraft Engineer by trade
See my below post
Mount for light bar / spot lights
The bar has to be solid as it will have two LED Cibie Super Oscars on it. The current mounts are not easy to attach and I don't like leaving the lights on the car when I am not driving long distance. I should have been more specific in my post because light bar has a different meaning these days to some people. Thanks for all the replies and the ideas, I have thought of mounting an LED light bar between the Cibies so one or the other could be used depending on circumstances.
