(Newbie) golf mk5 1.9 TDI : losing all electric systems when left in the sun...
Hi all, newbie here.
I have a golf mk5 1.9 TDI 2004 with a very particular issue :
- Car stays parked in hot sun for 2-3 hours
- when started, car will run fine for 10-20mns
- then electric systems go down one by one
- A/C (only fan was active at the time, not A/C)
- turn signals / stop lights
- sometimes car radio (not always)
- power windows
- all dashboard light and screen
- then finally the engine stalls... fun when you're on the highway...
- If I try to start again : no power at all (dashboard lights and screen off) : nothing
- If I wait one minute: dash lights come back, but the car can't start : starter stuttering (clack-clack-clack) like with a dead / weak battery
- once I leave the car off for a few minutes (2-3), the car will start again and run for 5-10 mns
- then the cycle starts again...
This seems to only happen only when the car has been sitting in the sun...
What I've tried so far:
- I've checked as much as I could of the electric wiring, fixed a few messes the previous owner(s) did
- checked and replaced any fuse that seemed in bad shape (found some that look slightly corroded, and one blown, with copper wire to "repair" it... :facepalm:)
- checked light connectors and repaired / replaced when needed (one had a pin burnt : replaced the connector and soldered new wire with clean pin)
I've done extensive research but couldn't find anything about it...
Anyone has any idea ? going crazy trying to find the fault here !
Much thanks!
Dan
