Caddy 2014 starting issue
I have a caddy maxi life 2014 model with a 19 desiel engine.
It has a starting issue where it turns over fires up but instantly stalls. To try to start again you have reset key and start starting process again . If it keeps running after start up there is no issues with engine operation acceleration or power. Some times it start 1st other times it can take up of 5 attempts before it starts.
At what voltage does the the ecu shut off as i am wondering if I have a voltage drop issue or failing battery. I have had the battery tested and they said it was OK.
When I hooked up my Ros Tech VCDS the voltage drop at terminal 30 can drop below 10 volts when starting.
