2014 90TSI 1.4L Mk7 Golf Wastgate Rattle 1300 RPM 6th gear
Hi Guys....need some help with this one
I have a 2014 90TSI 1.4L Mk7 Golf DSG running BPUltimate98, 504/507 oil,85,000Km and after spending many hours trawling through the www I found this on Youtube
Engine rattle - VW golf Mk7 1.4tsi - possible wastegate rattle - YouTube
This sounds like a wastegate rattle which seems identical to mine and I have quietened it down substantially by using a spring from Bunnings similar to this on a BMW BMW 340i 2016 B58 Engine. Wastegate actuator won’t rattle anymore. - YouTube
The rattle occurs at about 1300rpm when the car is in 6th gear (DSG - 52kph) and applying the throttle going uphill just before it changes down to 5th. or revs build to over 1600.
The WG lever and bushing have less than 1mm play in them, the WG actuator is electric not vacuum like most shown on Ytube and moves freely to open and closed positions.
Ups, bist Du ein Mensch? / Are you a human?
Is it OK to adjust the rod to take up the slop(pre-load) or do I seek out some-one with VCDS to check the adjustment.
The dealer fitted a clip when car was bought new but I wonder if there could be another underlying cause?...Plugs,Coil, Detonation, Pre-ignition?
The car is grandma driven and new plugs fitted 25K km ago, no EPC light on dashboard.
