Hi. Can anyone advise where the radio antenna is located in the MK6 wagon? The shark fin is a dummy and no coax connection to the tail gate window.
Either in the back tailgate window or the rear side windows.
Thanks. Now finding out how to get to the side windows.
What are you trying to do? Or what is the problem you are trying to fix?
FM reception is getting weaker.
There is a radio signal booster (amplifier) on the hatchbacks so I can only assume the wagons have it also. This may be faulty on your car?
This might help you locate the signal boosters etc, although its a Mk7 wagon now a Mk6 (should be similar though).
https://youtu.be/YDSQ7MEqzmc
Also this should help with part numbers for the antenna signal boosters etc: Antenna & Radio for 2013 Volkswagen Golf | VW Parts Vortex
