New Crafter 130kW Maintenance Info
Spoil alert, many will find this boring.
In this thread, I'm going to post some basic info on basic maintenance and parts. This thread will be frequently updated.
CRAFTER 2021 4MOTION
ENGINE OIL CHANGE
Oil filter ......... Mann HU7020Z
Air filter ......... Mann C29036 or Wesfil WA5546 (Burson, Auto Pro)
Cabin filter ..... Mann CUK26009 or Ryco RCA270M
Engine oil ....... Fuchs GT1 PRO C-3 ......... 9.4L (103kW engine takes less than that)
Sump plug ..... M14x1.5mm
AUTOMATIC TRANSMISSION
Oil/ATF ........... Fuchs ATF6008 ............... 7.8L (dry fill)
MANUAL TRANSMISSION
Oil .................. Fuchs SINTOFLUID FE75W.....3L
COOLANT
Capacity ..... 14L
Use genuine coolant, in emergency for top up, you can use distilled/demineralized water if you don't have coolant.
Then as soon as you can, adjust the coolant concentration to 50%.
ADDBLUE ..... 18L capacity
BRAKES
Front brakes
Pads ..... BOSCH
Discs ..... DBA3730E ..... 303mm ..... option 1LA, 1LB
Rear brakes
Pads ..... Pagid T2733, BOSCH
Discs ..... DBA2777E ..... 300mm ..... option 1XO, 1X1
Also available are DBA2777S (slotted)
Rear brakes are the same as on Amarok V6
ELECTRICS
Battery ..... DIN85LH AGM
