UPGRADE to lighting
2010 Passat CC with dynamic headlights - single Ds1 globe per light.
high beam is achieved by changing the shrouding around the globe.
So how do I trigger a relay to activate supplementary lights that I’ve fitted ??
Checked the connection at the passenger side light and can’t see a 12v source that’s usable - as in controlled by the high beam switch.
thanks in advance
Yes the AFS high beam shutter is controlled by the AFS module by a CAN signal from the SWCM.
You can trigger a relay from pin 11 (0.5mm yellow with black trace) at the 14 pin headlight connector either side.
https://www.vwwatercooled.com.au/for...hpdi7CX2-1.jpg
YES Thank you …. One of the easiest wiring installations I’ve ever done !!
