Originally Posted by
Bambazonke
Hi there Flipper Dog
I have a MY21 T Cross with a 2Q Valeo A5 ECU and am trying to activate Sign Assist without much luck to date. Coding in the 17 kombi and 5F MIB3 (without Nav) head unit appears to be the same at the T Roc Tiguan Golf etc. However in the A5 camera ECU instead of Byte 16 bit 4 it is a combination of codes in Byte 12 Bits 3 to 7. I have tried a number of combinations here and it still does not work.
I am also not sure if it is a bus setting in the 5F ECU as I have seen Extended, Infotainment and Comfort options all being used but this may because different head units may have been installed. At this stage I am leaning on the Infotainment option.
In VCDS I am able to see 3 "fusion" options in the Adaptations drop down menu which are currently set to activated, road sign detection and the numerical value of 0. Are you able to see this last setting in OBD Eleven and if so what is the value?
Thanks
