Originally Posted by
joecepi
Sorry if you have worked this out already, just joined today.
Recently went through this myself with a 2017 V6. I think it all depends on what was ordered with the tow bar from the factory. Mine had the 13 pin euro to 7pin. The only additional wire in the 13pin factory socket was a perm 12v. You may have more if it was specked when ordered. I ended up just wiring a couple of 12v lines on relays for fridge and charge for the brake away. Just swapped the 7pin for a 12pin flat and wired directly into it. Still used the VW loom for all the regular lines for light etc.
I also had to run an extra line for the brake controller. It was easier to just run these directly to the 12 pin flat rather than into the 13 pin socket and then through the loom to the 12 pin flat. There is also no 12 or 13 core wire available in Aus.
Hope that helps.
