T5.1 Service - Fuel, Air and Cabin Filters
Hi all wondering if someone can please clarify.
I change my oil every and oil filter every 10,000km - normal schedule states 15,000km intervals.
So the fuel filter would require changing every second service? So every 30,000km interval?
Air filter every 15,000km - could this stretch to 30,000km?
Cabin filter - every 30,000km?
Is there a quick reference user guide to this sort of stuff somewhere?
All filters work better and better as they ‘block’ right up to the point they are too blocked. On a truck the air filter will be replaced when intake suction exceeds a maximum level not to an arbitrary time. A new filter is not a better filter.
A light tap is incredibly effective and if you own a 4wd driving in dust an enormous amount of surface dust collects which is easily removed.
I actually use a vacuum cleaner from time to time as also keep the intake box clean from dirt and debris that collects before the filter.
Fuel filters cannot usually be visually inspected so need disciplined changes but air and cabin are the mechanic$ friend like brakes to replace early and often.
